Home > General > Nav Help
Big Dave
Nav Help
I've just purchased a 55 sc and have found that the Nav is showing no signal (red line through icon) the previous owner has said it's got the 2012 disc in and needs an aerial upgrade? Is this true, and if so can I just put an earlier disc in and get it running?
Thanks in advance.
Post #392026 Sat Aug 17 2013 11:43am
Paddi
Never heard that later discs need an aerial upgrade. Sounds like b Censored t. Have you checked the GPS aerial is still plugged in to the back of the sat nav unit under the passenger seat? If you have the sharkfin on the roof check the connection underneath. Think there was thread about this describing how it is possible to access it by opening the rear hatch and pulling down the rubber seal and headlining but you'll need to be careful. 2008 MY Java Black TDV8 HSE
Post #392031 Sat Aug 17 2013 2:04pm
mlines
Is it a 2012 disc for a 2005 car, or is it a disc from a 2012 car (which will not work)? 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit
Post #392037 Sat Aug 17 2013 3:08pm
mse
2012 don't have discs so it must be a 2012 disc Mike
2014 Facelift Discovery
Post #392064 Sat Aug 17 2013 7:17pm
Big Dave
Thanks for the replies, I'll have a rummage around tomorrow and check the connections. 2011 Evoque Si4 Dynamic plus lux
2007 Audi TT 3.2 V6
2005 Sport Sc
Post #392079 Sun Aug 18 2013 1:38am
Big Dave
All of the connections seem good, and I've checked the disc, it says 2011-12. As the maps all load ok so I'm guessing it must be the receiver. I'll confirm when I receive the replacement.
Thanks again 2011 Evoque Si4 Dynamic plus lux
2007 Audi TT 3.2 V6
2005 Sport Sc
Post #392089 Sun Aug 18 2013 9:31am
