Home > Maintenance & Modifications > Front suspension arms |
Advanced Factors Site Sponsor Member Since: 26 Apr 2013 Location: Southampton Posts: 289 |
I would do the whole lot....
Thu Aug 15 2013 9:28pm |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 |
Thanks for the reply. Sounds expensive! How much extra am I looking at? I have always tended to stick with genuine LR parts. Are the aftermarket ones any good or better?. Also forgot to mention that my RRS has dynamic response, not sure whether that makes any difference. 2014 L405 SDV8 RR Autobiography 2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone 2007 RRS TDV6 HSE - Zermatt Silver - Gone Last edited by JasM on Thu Aug 15 2013 9:41pm. Edited 1 time in total |
Thu Aug 15 2013 9:38pm |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 |
You will have to cut the arms off as I did
Thu Aug 15 2013 9:40pm |
Parts come with 2 year warranty from AF |
Thu Aug 15 2013 9:42pm |
Sounds good. Did you just replace the front arms or was there any additional work carried out? 2014 L405 SDV8 RR Autobiography 2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone 2007 RRS TDV6 HSE - Zermatt Silver - Gone |
Thu Aug 15 2013 9:49pm |
I did the ARB bushes /lower arms and track rod ends
Thu Aug 15 2013 10:03pm |
I take it that has pretty much eliminated the knocking noise? 2014 L405 SDV8 RR Autobiography 2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone 2007 RRS TDV6 HSE - Zermatt Silver - Gone |
Thu Aug 15 2013 10:09pm |
Yes but a right pig to do |
Thu Aug 15 2013 10:18pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9013 |
I found that new ARB bushes cured the knock from my suspension. I had the front arms done recently as one was apparently showing signs of excessive wear. LR garage asked me why I was changing both sides when only one side was showing the wear. Seemed a bit confused that one might do both whilst doing one. 2012 SDV6 - it's missing a couple of cylinders
Thu Aug 15 2013 10:36pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4420 |
Front lower arms are a doddle to do, if you go into the job knowing the bolts will need cut out, and you possess a 9" grinder
Fri Aug 16 2013 5:49am |
Local LR dealer that did mine said that an alignment wasn't usually necessary! I told him to do it anyway "just in case". 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Fri Aug 16 2013 2:21pm |
Don't worry, I won't be doing the work. I have booked it in with yourselves at Strathearn, so hopefully it won't give you too much trouble. 2014 L405 SDV8 RR Autobiography 2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone 2007 RRS TDV6 HSE - Zermatt Silver - Gone |
Fri Aug 16 2013 3:55pm |
