Home > General > FRONT SEAT removal?!? |
Quite easy actually...
Sun Aug 11 2013 1:04pm |
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 324 |
Many thanks...that's exactly what I needed to feel confident to to the job. Some one mentioned that there might be issues with air bags? Have you any experience or thoughts?!? Andrew Kennedy |
Sun Aug 11 2013 3:17pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
You shouldn't have any issues if you disconnect the battery earth but box clever as you will need to be able to move the seat back and forth to get at bolts of I remember. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Sun Aug 11 2013 3:26pm |
Thanks again for coming back. I am almost feeling I can get on with the job of taking the seat out.....but I dont like the word SHOULDN'T.....I would prefer the work WILL NOT. What do you think? Andrew Kennedy |
Sun Aug 11 2013 8:06pm |
Just make sure the SRS system is rendered safe.
Sun Aug 11 2013 8:10pm |
If you disconnect the battery you won't...... Better? Worse thing you can do is turn on ignition while seat is out and you'll need air bag light switched off. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Sun Aug 11 2013 8:33pm |
