Home > General > FRONT SEAT removal?!?
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
I need to check the wiring under the drivers seat - I think there is a wiring short to do with the GPS - can anyone tell me the proceedure? Am I likely to run into any problems with disturbing any Air Bags? Andrew Kennedy
Post #391429 Sun Aug 11 2013 11:17am
Bobby
Quite easy actually...
Cool Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #391444 Sun Aug 11 2013 1:04pm
andrew kennedy
Re: FRONT SEAT removal?!?
Many thanks...that's exactly what I needed to feel confident to to the job. Some one mentioned that there might be issues with air bags? Have you any experience or thoughts?!? Andrew Kennedy
Post #391447 Sun Aug 11 2013 3:17pm
simple1
You shouldn't have any issues if you disconnect the battery earth Thumbs Up but box clever as you will need to be able to move the seat back and forth to get at bolts of I remember. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #391448 Sun Aug 11 2013 3:26pm
andrew kennedy
Thanks again for coming back. I am almost feeling I can get on with the job of taking the seat out.....but I dont like the word SHOULDN'T.....I would prefer the work WILL NOT. What do you think? Andrew Kennedy
Post #391463 Sun Aug 11 2013 8:06pm
Bobby
Just make sure the SRS system is rendered safe.
Remove the ignition key, disconnect battery - earth lead first.
Wait 2 minutes for the SRS power circuit to discharge (in order to avoid the risk of
accidental deployment) before commencing work. Malaysia Boleh!
Post #391464 Sun Aug 11 2013 8:10pm
simple1
If you disconnect the battery you won't...... Better? Worse thing you can do is turn on ignition while seat is out and you'll need air bag light switched off. Shocked 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #391467 Sun Aug 11 2013 8:33pm
