Home > Technical > Alignment
Tony666
2005 Range Rover Sport TDV6 HSE Bonatti Grey
Alignment
I have excessive wear on the inside of my tyres (front), and the steering wheel doesn't sit straight. I understand I need 4 wheel alignment carried out, and after a bit of digging on this forum understand that the vehicle needs to be set into 'tight tolerance mode' for which specialist kit is required.
Can anyone confirm that this is neccessary, as all the garages in the Birmingham area I've tried haven't known what I was on about, even wheel alignment specialists. I understand that this mode prevents the suspension auto-levelling while the work is carried out, is there another way, I.e. door/boot open, fuse out, hazards on or any other crazy method that seems to get banded about to stop these cars doing their own thing!! Twisted Evil
Post #391251 Thu Aug 08 2013 2:11pm
Beancounter is an expert on this subject and i'm sure he will be along soon after his afternoon nap to advise. Thumbs Up
Post #391253 Thu Aug 08 2013 2:14pm
flack
Yes TTM is set to keep everything nice and tight during the 4 wheel alinement, once its put in to TTM you will get a red warning on the dash of an unstable car icon.
Once its set you just return control to ecu, just done one yesterday..
Flack Thumbs Up
Post #391271 Thu Aug 08 2013 6:08pm
Re: Alignment
Tight tolerance mode actually makes the suspension system work harder so that it sits more correctly. Trying to prevent the vehicle doing its thing is the wrong thing to do. 2012 SDV6 - it's missing a couple of cylinders
Post #391276 Thu Aug 08 2013 6:31pm
Bomber H
Re: Alignment
The steering wheel on mine wasn't sitting quite straight, seemingly aiming a little to the right in order to go straight ahead, so I had the 4 wheel alignment done today, and its no better! Censored
Going back tomorrow to let them know. 2016 VW Golf GTD DSG
2007 Exige S British GT SE
Gone : 2011 3.0TDV6 HSE, Stornoway Grey, Ivory, Piano Black Trim, Paddleshift, Privacy Glass, Side Steps, Mud Flaps, Heated Steering Wheel, Timed Climate & Remote Park Heating Smile
Post #391290 Thu Aug 08 2013 9:19pm
I've got to get my alignment done again soon as it seems to have drifted, will ask about the TTM.
@ Flack - what are the consequences of having the car lined without it in TTM? ON THE WAY: BMW F21 M140i
Post #391298 Thu Aug 08 2013 10:22pm
Camber, tow and wheelbase change with ride height. As the RRS has a large ride height range, there is an associated large change in camber etc. With the vehicle in normal tightness mode, the EAS allows the suspension to be within a fairly large tolerance in order to prevent the system working overtime to stay within tolerances i.e. it means the compressor doesn't have to run all of the time. In tight tolerance mode the system works hard to keep the suspension within much tighter tolerances.
If you set up the suspension in normal mode the vehicle could be sat at the extremes of its large ride height tolerance with the result being that the wheels could have markedly different camber etc. If you then set the camber etc. at that ride height combination and the vehicle is driven away, the ride heights can change and the alignment is now wrong. By setting the system to tight tolerance mode, you make sure the vehicle is sitting more correctly. The result is that the alignment will be more accurate.
You can set the vehicle's alignment in normal mode and get a good result IF the vehicle happens to be sitting with similar ride heights around the vehicle. But you are relying more on a bit of liuck.
When I last had mine checked, the guy doing the work showed me how the system picked up changing camber and toe measurements as he moved the vehicle slightly by leaning on it. It's amazing how sensitive the alignment systems is. 2012 SDV6 - it's missing a couple of cylinders
Post #391302 Thu Aug 08 2013 11:33pm
Thanks RRSTDV8 Bow down Thumbs Up ON THE WAY: BMW F21 M140i
Post #391304 Fri Aug 09 2013 5:15am
flack
@RRSTDV8
I could not of explained it better good explanation on how it works.
But one thing still keeps being missed when some centers do the 4 wheel alignment is making sure the steering wheel is straight after they have done it, I even used to check this before we had laser alignment gear, one consequence of not doing this check after your wheel alignment is that if they move it quite a bit to get it straight then you might end up having to calibrate the steering angle ecu if it spits it's dummy out and throws up all sorts of warning's.
Flack Thumbs Up
Post #391312 Fri Aug 09 2013 7:34am
Thanks Flack Thumbs Up ON THE WAY: BMW F21 M140i
Post #391318 Fri Aug 09 2013 9:28am
Tony666
Ok, can anyone tell me what type of equipment is required to put the car into tight tolerance mode?
Post #391319 Fri Aug 09 2013 9:30am
I believe the manufacturers of 4 wheel alignment systems (Pro-Align, Hunter Hawk etc.) do an add-on module for their systems that allows the technician to set the vehicle to TTM. How many tyre places bother to buy that module is the question. I guess you'll just have to phone around and ask. Alternatively, take your vehicle to a LR dealership - they will do the 4WA with it in TTM. How good a job they do is a moot point however.
Alternatively, you could buy an IIDTool or EASTool from Gap Diagnostics. The former allows access to read and clear all fault codes and gives access to various live values etc. The latter tool just allows control of the suspension system. Excellent little devices (about the size of a cigarette box, or maybe a little smaller). I have an IID and have used it to reset my FBH, set TTM for an alignement by my local tyre place and check various fault codes. Lives in the glove box and is updated by the manufacturer as further features are developed. 2012 SDV6 - it's missing a couple of cylinders
Post #391323 Fri Aug 09 2013 9:50am
It seems that RRSTDV8 is the in house expert Thumbs Up not Bc Whistle Well explained RRSTDV8. Bow down
Post #391326 Fri Aug 09 2013 10:35am
Just passing on stuff I've picked up on my travels through t'web as I tried to figure out a tyre wear issue on my RRS. Thumbs Up
I have never understood why LR chose to build the D3/4, RRS and FFRR with adjustable suspension that would make a race car look simple. For something designed to thump around off road, it seems slightly odd to me. 2012 SDV6 - it's missing a couple of cylinders
Post #391327 Fri Aug 09 2013 10:52am
flack
It is because they are off road vehicles and the travel in the suspension when going off road is so big, they need this when the electronics kick in so the car can detect what to do at what corner when it is climbing or in ruts its all to do with center of gravity and keeping the car level as much as possible.
Flack Thumbs Up
Post #391330 Fri Aug 09 2013 12:18pm
