Home > Technical > Dtc's |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9005 |
http://www.therangerstation.com/tech_library/OBD-II_codes.html
Mon Aug 05 2013 7:25pm |
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 |
Many thanks. Tail lights eh? I'll have a
Mon Aug 05 2013 7:38pm |
I see you've asked about tail light bulbs in another thread. Had one blown and has replacing it sorted your other issues? 2012 SDV6 - it's missing a couple of cylinders
Wed Aug 07 2013 9:49am |
Those codes are must have been read with a basic code reader as the sophisticated models will read a further two digits that are Land Rover specific. P0504 is 'brake switch A/B correlation' - may be worth changing the brake light switch as it is a common source of many faults. Easy DIY and switch costs about £17 P0157 is 'O2 sensor circuit low voltage bank 2 sensor 2' I'd try clearing that one and see if it reoccurs before going any further The new compressor software is recommended and any good independent LR specialist can install it for you. Is your new battery LR supplied or generic? Give it a good full charge with a smart charger. For a hard reset just disconnect both battery leads and connect them together for 30 seconds with a jump lead. But be very careful to ensure nothing touches the battery terminals. 2008 MY Java Black TDV8 HSE |
Wed Aug 07 2013 11:50am |
thanks for the replies. have not tried the bulbs yet. |
Wed Aug 07 2013 12:41pm |
