Home > Technical > Compressor software. |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
It might cure it but did you check for leaks as well when you replaced the pump, and did you check all the ride height sensors, just look at the 4x4 info screen and see what the little lines are doing.
Wed Aug 07 2013 8:45am |
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 |
Thanks for your reply. i had it fitted by a land rover indy so i'm hoping they did check for leaks etc. |
Wed Aug 07 2013 9:06am |
