Home > Technical > Compressor software.
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
Just had a new compressor fitted. Do i need the new software? i only ask as since fitted my dash board has lit up with all the supension symbols but no dtc are being recorded and goes into normal ride height only. thanks
Post #391109 Wed Aug 07 2013 6:27am
flack
It might cure it but did you check for leaks as well when you replaced the pump, and did you check all the ride height sensors, just look at the 4x4 info screen and see what the little lines are doing.
Some RRS I have upgraded to the new software have not liked it so you might just have to try it.
Flack Thumbs Up
Post #391120 Wed Aug 07 2013 8:45am
SCdavies
Thanks for your reply. i had it fitted by a land rover indy so i'm hoping they did check for leaks etc.
Post #391124 Wed Aug 07 2013 9:06am
