Home > Wheels & Tyres > 19" wheels - is there are difference between MY's? |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 |
There was a thread on here some time back about this and I believe certain !9's were a problem - the ones you show fitted my last MY10 3.0 TDV6 and I think TDV8 if that helps
Thu Aug 01 2013 10:59am |
mav101 Member Since: 22 Jan 2013 Location: Bromyard Posts: 28 |
Thanks for the info... had a search and found lots of interesting posts... but still not 100% clear... i'm looking at a few of these at the moment - all the 5 V type... am i correct in thinking there are 2 slightly different versions of this particular style of wheel? (just from looking at the pictures the centre hub looks a bit different, and there are hollows around the inside of the rim on some)... and that i'd need the earlier one? would the pic below be the earlier style? and the one i'd need to ensure Brembro clearance...
Thu Aug 01 2013 11:31am |
The dimpled rim is the earlier model
Thu Aug 01 2013 11:37am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
I have the style shown in your first post fitted on my TDV8. There isn't much clearance between the Brembo caliper balancing weights and the inside of the rim but they do fit. 2012 SDV6 - it's missing a couple of cylinders
Thu Aug 01 2013 11:57am |
interesting, thank you all
Thu Aug 01 2013 1:42pm |
Found this
Hope it helps Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW Still hoping for a S2 one day! |
Thu Aug 01 2013 1:54pm |
xiaofeng Member Since: 09 Feb 2014 Location: Shanghai Posts: 1 |
Absolutely different if you put them on brembo caliper (which's bigger, rotor's big as well to 360, 380 or 405), despie they have same offset and same J number (say 19x9J). I saw ppl here twisted it with J size and offset, sure J size matters, a 19x8.5J cannot match; also offset matters, a 19 wheel with ET 55 cannot match. But if I give you three different desigh wheels but same J, same ET (say 19x9J, ET53 as original), they can all clear brembo caliper? Answer is: not really!
Sun Feb 09 2014 2:20pm |
