![]() | Home > General > What is this button for? |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
Is it the button for the adaptive cruise control, to change the distance for the sensor |
^^^^ What Nick said |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
Yep ^^^ wot they said |
^^^^ Yes they are all correct... |
SPX Member Since: 27 Dec 2012 Location: South Yorkshire Posts: 587 ![]() ![]() ![]() |
Thanks for the advice, I'm assuming that the feature is very similar to Mercedes version which is known as Distronic. |
Similar but the Merc system works |
Last time I used my ACC it worked perfectly in an endlessly, tedious, 50 mph speed restriction in narrow lanes on the motorway with other vehicles close in front and to either side but then later in lane three at 80 mph with no vehicles ahead it took exception to a bright screaming orange Ford Focus RS alongside in lane two and slammed on the brakes.
^^^ sounds like it Paddi but credit where credit due, it must have the antichav feature turned on |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
I use the ACC quite a lot on long motorway runs. Works well although I sometimes use the throttle to override it when I can see that it might be about to do its "hard braking for no reason" trick. I have found that it works best when set to longer gap spacings as it comes off the throttle earlier so usually doesn't need to brake so hard. 2012 SDV6 - it's missing a couple of cylinders
Coolbanana Member Since: 24 Oct 2012 Location: Buckinghamshire Posts: 38 ![]() ![]() ![]() |
Really like the ACC - use it all the time on long motorway trips and even some A-roads. I have the little paddle instead of the button on my steering wheel though for changing the distance; below the gear change paddle. Mine is the SDV6. Current car: Porsche 911 Carrera S PDK (997.2) Past Car: (MY12) Range Rover Sport HSE SDV6 - Orkney Grey with Almond interior
So how do you know when it's going to do it? Or are you just psychic? ![]() ![]() |
So just like the bog standard cruise control then ![]() MERCEDES GL350 - Metallic Navy Blue w/Grey interior GOING: BMW F31 335D MSport+ xDrive Touring GONE: Land Rover Discovery 4 HSE - Stornaway Grey w/Black Interior (wish we'd kept it ![]() GONE: BMW F10 520D MSport - Carbon Black GONE:MY12 RRS SDV6 HSE Sumatra/Ivory/Grand Black Privacy glass |
I've learnt how it reacts by observing how it behaves in given situations. Having done that, I'm able to anticipate the system and adjust accordingly. It's something humans are really good at - learning and applying knowledge. ![]() 2008 TDV8 - it was a labour of love and is much missed |
But unlike bog-standard cruise control, one has the benefit of a system that is always looking in front of the vehicle and can react to situations even if the driver isn't fully concentrating on the view ahead. It's a useful addition to the tools available to the driver and certainly more useful to me than stuff like an internet hotspot in the vehicle (I think that was one of the items suggested in the recent LR questionnaire). The ACC isn't perfect but then neither is standard CC. I'd rather have ACC than standard CC - I've had standard CC on previous vehicles and only used it in roadworks covered by average speed enforcement cameras. Other than that I found that I had to intervene all the time. ACC reduces the incidents of intervention by a huge number in my experience. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
