Home > Technical > LTB00204v4
Rangeyr01
LTB00204v4
Does anyone know if this TSB is still relevant? Can I take my RRS in for this?
Many thanks
Ross
Post #389732 Tue Jul 23 2013 7:14pm
Paddi
Is this one of the series of TSBs regarding front suspension knocking noises? The short answer is 'yes' Technical Services Bulletins describe diagnosis and fixes for problems. They are not the same as recalls.
The work and parts are not free though Big Cry
Doesn't seem quite right somehow - LR fixes an inherent design fault and then charges the customer for it. 2008 MY Java Black TDV8 HSE
Post #389793 Wed Jul 24 2013 2:01pm
Rangeyr01
Oh that is rubbish I thought it would at least be labour paid Sad.
Kind of makes you think is it worth taking it to main dealer or a specialist with a lot cheaper labour rate.
I do have one of the Extended warranties but they don't seem to cover much Sad
Post #389794 Wed Jul 24 2013 2:13pm
Rangeyr01
oh and yes it is regarding the front knocking noise. not to sure about the squeaking air suspension though. sounds like a crap bed.
Post #389795 Wed Jul 24 2013 2:14pm
Paddi
When you take your P&J in to the workshop (preferably a good indie) ask them to go step by step. So instead of going the 'whole hog' straight away and changing the anti-roll bar (ARB) bushes AND removing the front body dampers AND fitting the mass damper kit. Just ask them to do the ARB bushes first and see if that cures the problem. It's a quick and easy inexpensive job. It's been reported on here by the most reliable sources that an even quicker and cheaper fix is to fit shims to the existing ARB bushes. The shims are an official LR part designed for the purpose.
That's assuming the inspection shows the ARB bushes are shot and the other bushes in the arms and drop links and the ball joints are all OK. 2008 MY Java Black TDV8 HSE
Post #389807 Wed Jul 24 2013 5:05pm
Rangeyr01
Thanks Paddy, I will ask them to do that.
Got it booked in on Monday just to diagnose it etc no work being carried out.
Taking it to a local specialist DSE in macclesfield.
Post #389821 Wed Jul 24 2013 7:05pm
