Home > General > stereo error message
dal1557
hi all
when i try and turn my music up loud i get a message on my stereo screen saying power saving mode????
my rrs has had a new battrie but still no joy
can anyone help me out here as in how to stop this ???? D Ledingham
Post #389098 Wed Jul 17 2013 2:45pm
Did you have your alternator tested at the time you replaced your battery? Common problem alternators if you've had to replace the battery. Its usually the cause of the battery failing. Is it a genuine L/R battery?
Post #389101 Wed Jul 17 2013 3:32pm
dal1557
hi and thanks for your reply not to sure if its a landrover battrie but i will check when i get home ive not long bought my rrs
what size of battrie should be in the rrs?
its - 2005 2.7 diesel D Ledingham
Post #389103 Wed Jul 17 2013 3:39pm
Its critical that you get the correct battery for these sports with them having such a temperamental electrical system. Confused
A bit of advice here for you to digest. Thumbs Up
http://www.rrsport.co.uk/forum/topic20976.html
Post #389114 Wed Jul 17 2013 7:41pm
Prelude
What you need is a new battery. Its because you have a battrie that you have the problem. A battrie will not deliver as much voltage as a battery. Laughing
Post #389133 Wed Jul 17 2013 11:14pm
Bodsy
Site Sponsor
Just a simple question, but is the engine running when you get this message? You will always see it if the engine is not running and you turn it up loud.
If its doing it when the engine IS running, then I strongly suspect a) battery which should be around 900cca but I have seen Some with only 750cca which start ok at the minute.... They should have been for the v8 petrol ones though.
Check the battery voltage with everything off and the engine having not been run at all for an hour. then start her up and see what the voltage increases to after 1 minute.
Should be sound 12.4-12.7 and then at least 13-13.5 after a minute, but may be up to 15.
If it doesn't really increase, then fubared alternator. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #389173 Thu Jul 18 2013 8:42am
simple1
It could always be the brake light bulbs Whistle I'd go with Bodsy's diagnosis. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #389182 Thu Jul 18 2013 11:42am
Did you resolve this issue Question
Post #389539 Mon Jul 22 2013 9:53am
dal1557
no not yet am offshore til tomorrow
any ideas??? D Ledingham
Post #389565 Mon Jul 22 2013 1:55pm
Only the ones suggested above.
Post #389568 Mon Jul 22 2013 2:30pm
