![]() | Home > General > fuel flap problem, just can't find solution here :-( |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 ![]() ![]() ![]() |
Hi everyone !
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Try the manual release from inside the boot, see if that affects / corrects behaviour (door in boot sidewall, tab, pull to release) |
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 ![]() ![]() |
Probably a broken part inside the latch (or a faulty actuator). Like this site? Buy some RRSPORT goodies to show your support! |
ok so i did some digging. i have tried the manual release and this didnt solve the problem. The manual release is simply releasing the locking pin, but this is already being done when i am unlocking the car via the key fob.
Also check that the clip and the rubber boot are present on the flap itself |
Thanks Chilly. I've been messing around this morning with the problem. Ive been pushing in the three plastic bits to see if this releases something, but nothing. I've been pushing the middle plastic bit to the left, right, leaving it in the middle, but nothing. What a pain.
Prelude Member Since: 29 Dec 2012 Location: Daan Saaf Posts: 57 ![]() ![]() ![]() |
Spray some silicone spray into the plastic bits to free them up (or WD40). i doubt you have done any real damage with the washer. they look a bit dry and maybe you moved some dirt when washing which then dried. i always give mine a squirt annually as part of my preventative maintenance program. |
This is a picture of my flap ive just taken for you |
Avoiding all gags about Ady posting pictures of his flap |
Shut it!!! |
Yes, your boot and clip are missing from the flap door |
Thanks guys. Thanks Ady for taking a piccie of your flap...it looks very clean |
Thank a million for that Martin. I wont be needing the parts yet but just in case i do in the future, or someone else needs them, we now know what the part numbers are !
We are happy to help |
