Home > General (L494) > Winter Tyres.... and Remote Heating...
PauloAmore
Scotland
Think i can keep my 20" 275 winter rubber to fit to winter rims that will be compatible with the new car?
Anyone going to take the chance that remote heating can be aftermarket enabled like the disco 4?
- Would save £1000 (but you'd be without the fob. Strathearn Engineering mentioned they'd enable it for £60. 2022 P440e AB
Post #386727 Sun Jun 23 2013 1:02pm
Carlo RA
Italy 2010 Range Rover Sport 3.0 TDV6 HSE Java Black
Hoping that the old holes are aligned with the new... Rolling Eyes
And however the wheel of my14 is larger, the 20" should be 255/55 Smile
Carlo.
Post #388671 Fri Jul 12 2013 8:32pm
mse
There is a thread on wheels, there are three potential issues:
Pcb is one thing
Tyre profile another
Wheel clearance over calliper a a final thing.
I would suggest there will be a lot to enable, if you get the right core stuff Mike
2014 Facelift Discovery
Post #388681 Fri Jul 12 2013 9:53pm
PauloAmore
Scotland
My dealer told me that the 275, 40 20 rubber will fit the new 20" alloys... 2022 P440e AB
Post #390994 Mon Aug 05 2013 6:27pm
Bob.
Data From the new RRS handbook:
Land Rover approved winter tyre sizes
19 inch wheels
235/65 R19
20 inch wheels
255/55 R20
265/50 R20
21 inch wheels
265/45 R21
275/45 R21
22 inch wheels
275/40 R22
The 20" wheels on the new RRS are an inch narrower than the old model 8.5J cv 9.5J - hence the new recommended width of 255 rather than 275mm.
Also fitting 275/40 R20 instead of 255/55 R20 will cause the speedo to over read by nearly 5mph due to the smaller diameter.
Post #391011 Mon Aug 05 2013 10:13pm
PauloAmore
Scotland
Confused 2022 P440e AB
Post #391012 Mon Aug 05 2013 10:16pm
Carlo RA
But the old rims you can mount the new model?
Post #391015 Mon Aug 05 2013 11:30pm
mse
THere is a spreadsheet with all the wheel sizes and types approved...i have it somewhere Mike
Post #391058 Tue Aug 06 2013 3:01pm
Cpd1
topix tyre fitments
Post #391067 Tue Aug 06 2013 4:28pm
mse
Thats the one...except in PDF... Mike
Post #391079 Tue Aug 06 2013 7:10pm
It doesn't answer the question as to whether the existing wheels will fit. My own view would be that as the wheel width (not diameter) has been reduced, there is a chance that the tyre will rub the wheel arch liner on full lock.
What would be useful would be for the first forum member to get a new RRS to meet with someone and try the new version with the old wheels. With care, no damage should be inflicted on vehicle or wheel. 2012 SDV6 - it's missing a couple of cylinders
Post #391101 Wed Aug 07 2013 12:28am
Carlo RA
In fact, my question was: you can use the old rims with new tires? the holes of the pins of the old rims will be compatible on the wheel hub? if I take the old rims can mount them on the new RRS using standard new tires?
I hope you understand why I translate with Google... Embarassed Whistle
Post #391127 Wed Aug 07 2013 10:34am
We don't know whether the old wheels will fit on the new RRS. The new tyres won't fit on the old rims because the new rims are not as wide as the old rims. 2012 SDV6 - it's missing a couple of cylinders
Post #391130 Wed Aug 07 2013 10:53am
Carlo RA
Big Cry I have 3 changes of wheels (summer, winter and off road) all mounted on rims! Big Cry
Post #391134 Wed Aug 07 2013 11:12am
embar76
Poland 2007 Range Rover Sport TDV8 HSE Java Black
The man from Land Rover service, told me that the rims will not fit, because they have other mount and dimension. Crying or Very sadI also have 3 old sets Evil or Very Mad
Post #408680 Wed Jan 08 2014 4:41pm
