![]() | Home > General > wheel alignment |
Anyone that knows what they are doing. And don't forget you need a full tank or added ballast to get the car sitting right! 2x TDV6. SE and HSE. Both returned to sender with issues👀
dal1557 Member Since: 30 Jun 2013 Location: Montrose Posts: 23 ![]() ![]() ![]() |
dont they have to use a computor to put the suspension in lock mode? is it not all set up by computor?
I have Bear four wheel system that we use for lorries with multi-wheel steering and set mine up after dealer didn't do it correctly. |
No, the advice is to use the diagnostic tool to set the vehicle to 'Geometry Set Mode'. Putting the vehicle into this mode will make sure that the ride heights are controlled more accurately. Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
That's a new recommendation. Might explain why dealer could never get alignment right. Certainly isn't on 2009 technical bulliten. Yet again, nice work Bobby |
Is not a new recommendation - has been around since the cars first came out and is the correct process so will not be in any technical bulletin. To do a wheel alignment correctly the car needs to be set to Tight Tolerance Mode (that is correct term). This needs to be done via a dealer or someone with a Faultmate etc. This narrows the tolerance level that the suspension computer maintains the car height at when at onroad height. You then get the alignment done in the normal way and then get the car taken out of Tight Tolerance Mode. I have never heard of loading the car up with bags of sand. Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
Maybe this first page will help..
