Home > General > wheel alignment
dal1557
wheel alignment
hi all what is best for wheel alignment on my rrs 2005 ? is main dealer the best option ?or just any garage? D Ledingham
Post #388562 Thu Jul 11 2013 8:54pm
simple1
Anyone that knows what they are doing. And don't forget you need a full tank or added ballast to get the car sitting right! 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #388563 Thu Jul 11 2013 8:57pm
dal1557
dont they have to use a computor to put the suspension in lock mode? is it not all set up by computor?
ive just heard that many diffrent stories
would kwikfit be a good option ? D Ledingham
Post #388568 Thu Jul 11 2013 9:43pm
simple1
I have Bear four wheel system that we use for lorries with multi-wheel steering and set mine up after dealer didn't do it correctly. Whistle Had straight steering wheel and perfect tyre ware after. Added 50kg to each footwell and empty tank and set it with suspension in normal ride as per dealer bulletin so not sure where locking it at access height comes from. As long as tech knows what they are doing, anyone can do it but personally, would chose a four wheel alignment specialist. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #388571 Thu Jul 11 2013 10:11pm
Bobby
simple1 wrote:
..so not sure where locking it at access height comes from...
No, the advice is to use the diagnostic tool to set the vehicle to 'Geometry Set Mode'.
Putting the vehicle into this mode will make sure that the ride heights are controlled more accurately. Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #388572 Fri Jul 12 2013 12:26am
simple1
That's a new recommendation. Might explain why dealer could never get alignment right. Certainly isn't on 2009 technical bulliten. Yet again, nice work Bobby Thumbs Up Bow down 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #388578 Fri Jul 12 2013 6:59am
garrycol
Australia
Is not a new recommendation - has been around since the cars first came out and is the correct process so will not be in any technical bulletin.
To do a wheel alignment correctly the car needs to be set to Tight Tolerance Mode (that is correct term). This needs to be done via a dealer or someone with a Faultmate etc. This narrows the tolerance level that the suspension computer maintains the car height at when at onroad height. You then get the alignment done in the normal way and then get the car taken out of Tight Tolerance Mode. I have never heard of loading the car up with bags of sand.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #388595 Fri Jul 12 2013 9:05am
Bobby
Maybe this first page will help..
 Malaysia Boleh!
Post #388605 Fri Jul 12 2013 9:45am
