Home > Technical > Bird noise coming from front left
c15ebb
On my 05 rrs At what seems around 30ish mph... radio off, left window down... i have a like bird chirping/rubbing sound coming from the wheel... happens when going straight or on bends sometimes but when i turn wheel only v slightly to right it stops, been doing it for a while now... only seems to happen around that speed ish...maybe tad less or tad more... but not when going slow slow
Any ideas? I was thinking maybe wheel bearing or something... passed mot about a month ago with nothing showing
Post #388161 Mon Jul 08 2013 6:44pm
Check to see if your wheel is hot after a journey Idea If it is, then your brake caliper might be sticking. Wink
Post #388177 Mon Jul 08 2013 8:42pm
could be a stone jammed in the pad too RRS gone
Post #388216 Tue Jul 09 2013 12:06pm
Bodsy
Site Sponsor
sounds to me like the wheel bearing is on its way out. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #388218 Tue Jul 09 2013 12:17pm
c15ebb
this is what im thinking.... but been like it for about 2 months.. wheel was tad hott but hard to tell really
Post #388268 Tue Jul 09 2013 9:00pm
drdelrrs
Does the sound change when...
a) with varying brake pedal pressure - if so probably brake pads or contamination on pad -stone; dust, oil etc.
b) left or right cornering at slow speed - if so probably a hub / wheel bearing issue
c) left or right cornering with or with acceleration (i.e. load) - probably a dry CV joint on drive shaft.
Post #388292 Wed Jul 10 2013 9:00am
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Re: Bird noise coming from front left
Have you tried asking the Mrs to sit in the rear? Rolling with laughter Rolling with laughter
I'll get my coat Rolling Eyes Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section Thumbs Up
http://rrsport.co.uk/forum/topic28424.html
Post #388694 Sat Jul 13 2013 2:28am
c15ebb
Think its a sticking caliper... as wheel is getting hotter than other side!
Annoying thing this car as i want to do it myself but cant jack the thing up like a normal car only need a cm of ground to get wheel off... im perfectly fine doing it myself thats why it annoying... need to find a friend of a friend with a car ramp
and haha kav.... i can wish i could say i have a Mrs Sad
Post #388705 Sat Jul 13 2013 9:00am
Bodsy
Site Sponsor
Jack it under the wishbone, will be fine Thumbs Up Bodsys Brake Bible
See it HERE
Post #388707 Sat Jul 13 2013 9:58am
