Home > Technical > Brake Vacuum Booster Pump Pipework (Brake Failure)
g8lmh
Third post.
Another issue discovered today during a drive.
Brakes suddenly went hard due to lack of vacuum.
Checked booster pump and found small diaphragm blown on the pipe work connected to booster pump. Hence loss of vacuum.
Anybody know where the pipe work/diaphragm valve can be perched and how do I know if my booster pump is goosed?
Last request. Can anybody explain how the booster pump knows to kick in? Loss of vacuum? When brake pedal is pressed?
Cheers.
Lee
Post #387993 Sat Jul 06 2013 9:11pm
GrahamS
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
There was a recall on the brake servo/vacuum pipe.
Have you checked to see if your vehicle had the upgrade?
I had mine done at the LR dealer a few weeks ago. Luckily they just had to fit the new style pipe rather than a new servo too.
All free of course.
Post #387998 Sat Jul 06 2013 10:22pm
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
As above - there was a recall on this part. Land Rover will change this for free under the recall if it hasn't already been done. Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section Thumbs Up
http://rrsport.co.uk/forum/topic28424.html
Post #388365 Wed Jul 10 2013 10:41pm
