Home > Faults & Fixes > Alignment rivits |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
It is a notch on the chassis that the cams rotate on so that the adjustment can be made some have been found to have been ground off.
Mon Jul 01 2013 8:33am |
i've know a few people to weld a spot on in it's place which has worked OK. Bodsys Brake Bible
Mon Jul 01 2013 10:09am |
As Bodsy says get something welded on in its place as long as its able to turn the against the eccentric washers you should be fine.
Mon Jul 01 2013 2:10pm |
looneyfitter Member Since: 13 May 2012 Location: liverpoool Posts: 212 |
Cheers lads any pics? There's a few washers from what I can see. Not sure where to weld |
Mon Jul 01 2013 4:01pm |
This is a view of the front drivers side lower front bolt you can see the washer hits the notch so when you turn the bolt it moves it off center.
Mon Jul 01 2013 5:55pm |
Cheers Flack. Are the rears the same? Mine has got them rivits so not sure what alignment place is on about now. Also on the front lower wishbones should the nut be front or rear?
Mon Jul 01 2013 9:04pm |
All the ones I have changed have the nuts at the front just like my picture..
Mon Jul 01 2013 9:24pm |
didnt realise you had replied to this. Thanks Flack |
Sat Aug 09 2014 10:38pm |
