Home > Maintenance & Modifications > Fitting Rear Tread Plate
steverrs
Scotland 2013 Range Rover Sport SDV6 HSE Ipanema Sand
Sorry if this has been covered, I've just ordered the rear tread plate and the LR instructions seem to indicate that you remove the plastic one before fitting this ? Has anyone fitted the genuine one ? Seller indicated it fitted over the plastic one and quotes its genuine article LR007321.
Thanks !
Post #386619 Sat Jun 22 2013 6:32am
mse
considering it takes 1 nano second to remove the plastic one have you just removed it?
The new one will have lugs underneath that slot into the holes left by the plastic one...im just thinking how best to describe it to you.
Im reasonably confident you have to remove the plastic to fit the new (chrome?) one Mike
2014 Facelift Discovery
Post #386634 Sat Jun 22 2013 9:15am
steverrs
Sorry have not I'm still in Afghanistan !
Post #386637 Sat Jun 22 2013 9:24am
mse
If you can see the underside of the new one then it might give the answer...but im sure you remove the old plastic one. Mike
Post #386638 Sat Jun 22 2013 9:33am
steverrs
Cheers Mike, flying home tomorrow so I will see it and the car then !
Post #386646 Sat Jun 22 2013 11:03am
