Home > Maintenance & Modifications > Fitting genuine twin towing electrics 2005 RRS
Rustbucket
England 2005 Range Rover Sport 4.4 V8 HSE Luxury Arctic Frost
How easy? does this require a software update once fitted? I guess that they plug into the rear loom and take a couple of hours?
Post #385736 Mon Jun 17 2013 5:11pm
Bodsy
Site Sponsor
A bit fiddly getting the loom over the harmonic dampers and clipped in place, but not technically difficult.
You don't HAVE to have the electrics enabled on that year car, but if you do, it tops the car automatically raising if your in terrain response mode.
Should also stop the reverse sensors beeping when you reverse with something plugged in.
Ill be over your way on Thursday (on way to Grantham) if any use. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #385742 Mon Jun 17 2013 5:25pm
Rustbucket
Thanks!! going to order a twin kit off ebay asap, didnt want to end up with an electrical nightmare!! I dont mind a few hours of work..........
Post #385743 Mon Jun 17 2013 5:30pm
Rustbucket
I'm convinced!! I was a bit suprised tbh when I removed the cover to find nothing fitted from the factory Sad
Is there much difference over the genuine parts against non genuine? I've seen both on ebay with a substantial price difference
Post #385782 Mon Jun 17 2013 7:39pm
Boner
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
LR Fitting Instructions
Hi. I have bought used twin towing electrics genuine Land Rover. I was wondering if anyone on the forum has the LR fitting instructions for these? They do look fairly simple to fit, however for ease and peace of mind instructions do always help. If anyone has any help or advice it would be appreciated.
Post #408107 Sat Jan 04 2014 5:25pm
