Home > Technical > Anti roll bar bushes
Jonesyscoob
I'm looking at changing the anti roll bar bushes front and rear on my 2006 4.4 hse, should I buy genuine lr parts or can I get local motor spares ones just as good or even poly ones? Local spares said there's 2 types depending on stability control, would my car have that? Or has anyone got part numbers
Thanks
Post #385737 Mon Jun 17 2013 5:13pm
Paddi
Probably best to use genuine LR. They were redesigned a while back and the new design is a bit beefier than original. If you have active roll control then there will be a reservoir under the bonnet near the front offside with a yellow cap. However if you order by 'phone from Duckworth Parts and have your VIN to hand they should be able to make sure you get the correct parts. There is a 'how to' on the forum here:
http://rrsport.co.uk/forum/topic28424.html
Does not look easy but obviously within the capability of a determined DIY.
Best of luck. Thumbs Up 2008 MY Java Black TDV8 HSE
Post #385898 Tue Jun 18 2013 6:37pm
