![]() | Home > Technical > Name this part and its purpose - please ? |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
^^^ Yep........but I don't know if they swing that much while driving...... FF 4.4 V8 Soooo looking forward to this bad boy
James @ Grange Barnet LR Member Since: 17 Oct 2012 Location: Barnet, North London Posts: 208 ![]() ![]() ![]() |
They are indeed Harmonic Dampers and are designed to swing as it were.
This is an old topic |
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 ![]() ![]() |
If you can't wrap them,how about putting some wire around it and fastening that to a suitable point to reduce the swing thus stopping it banging. |
B3EEE Member Since: 20 Apr 2012 Location: Wales Posts: 450 ![]() ![]() ![]() |
mine hit the rear bumper. Like I said, I think the HST bumper is larger and so nearer to these weights. I've jammed a cloth up there at present until I can think of a better solution |
bosun Member Since: 16 Dec 2011 Location: west wales Posts: 20 ![]() ![]() |
Mine had two extra ones fitted under warranty to stop a rattle ,these ones are at the front of the sill behind the front mudflaps,except the dealer fitted them the wrong way around !!
well, this is the only thing I can think of. the trouble is 'have you seen where they are located?' It'd be a total nightmare to remove them to change the mount rubbers ![]() ![]() Prefer RR Vouge S/C but they don't do Orange ! |
