Home > Maintenance & Modifications > Timing Belt Quote
msramsden
Timing Belt Quote
Hi All
I have received the following price from an independent LR specialist garage;
Front cambelt and tensioner replacement £285+VAT (parts and labour). We don't change rear the rear belt as it is not timed.
Does this sound right?
The dealership quote was around £1000.
I would have thought the issue would be the age/mileage of the rear belt would mean it would need replacing to prevent possible failure?
Any advice would be appreciated.
Post #384357 Thu May 30 2013 4:06pm
Bodsy
Site Sponsor
Ask them to also change the other two idlers. Shouldnt charge much more to change them and they'll bring the price up to about £330+vat
It's a good price, but I would still be wanting to get the fuel pump belt changed.
theyre right insofar as it's not timed, but it is a bitch to do which is why most say dont bother. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #384359 Thu May 30 2013 4:13pm
Slightly OT but I found an old receipt t'other day for a service and cambelt change I had done back in the mid-90s. Full 60k service and cambelt change was £180 incl VAT!
It probably felt expensive at the time... 2012 SDV6 - it's missing a couple of cylinders
Post #384365 Thu May 30 2013 7:09pm
msramsden
Thanks for the replies guys.
I'll give them a call tomorrow about the idlers and fuel pump belt.
Post #384367 Thu May 30 2013 7:20pm
msramsden
I wasn't even old enough to drive in the mid 90's Embarassed
Post #384368 Thu May 30 2013 7:22pm
jw
Yup I was quoted 300/400 quid of the top of his head for the belts done at my local inde ( he only gave rough quote as I bumped into while he was out walking his dog)
But he did say they dont bother doing the fuel pump belt as its a big job ( upping the bill) and they have never heard of one failing ( and if it does fail it doesnt do any damage to the car other than a break down due to no fuel )
Post #384389 Thu May 30 2013 10:09pm
mrfixit
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Would be interested to know who's doing it and how it goes,as I want mine doing.
Post #384395 Fri May 31 2013 7:04am
SRE
Spain
Maybe a new oil pump as well ?
Post #384402 Fri May 31 2013 8:53am
flack
I have changed dozens of cam belts front and rear and I would never advise a customer that it does not need doing, for one its a get out for LR if anything does go wrong, and 2 why would they recommend it needs doing at the stated times if was not necessary.
I have also changed a few oil pumps at the customers request because of the timing belt tensioner mount failing on the oil pump casing, again if its in the range of the oil pump casing possibly failing then I would not take the job on unless the oil pump was changed at the same time, as you can't be sure the casing is ok.
The rear belt is not that bad to do I have done worse ones...
Flack Thumbs Up
Post #384403 Fri May 31 2013 8:59am
msramsden
Thanks for the feedback guys. TDV6 HSE - Rimini Red
300tdi Discovery Commercial
Post #384424 Fri May 31 2013 3:03pm
msramsden
I have been quoted by Independent Landrover Services of Preston.
They have also quoted for some other repairs and their quotes have been significantly cheaper than the dealers quotes. TDV6 HSE - Rimini Red
Post #384425 Fri May 31 2013 3:06pm
