![]() | Home > General > Tyres |
As a starter for 10, I'd check the sticker on the inside of he door or the handbook and see what it states and make sure the tyres comply to the sizes there |
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 ![]() ![]() ![]() |
You want them marked XL, as they are the same size as BMW saloonsetc, and the RRS weighs twice as much. If you get 45 profiles your speedo would read wrong, and you would get a higher top speed but acceleration would be lower basically !
Should read a minimum of 106y as load rating. It will be printed on side of Tyres after the size marking. So should read 275/40/20 106Y XL or Extra load. Anything less than 106 will not be adequate for a Sport. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9055 ![]() ![]() ![]() |
Looking at the scarce info on the web about this tyre maker, they make 275/45/R20 106H and 275/45/R20 110V XL
Strictly, that is the speed and load rating in one: 106 is the load rating (950kg) and Y is the speed rating (186mph). ![]() 2008 TDV8 - it was a labour of love and is much missed |
Strictly, that is the speed and load rating in one: 106 is the load rating (950kg) and Y is the speed rating (186mph). |
Might help if you post in the right section in the first place ![]() ![]() But i'm sure that isn't the reason it got locked. ![]() http://www.rrsport.co.uk/forum/wheels-tyres-vf32.html ![]() |
reid7774 Member Since: 12 Apr 2012 Location: Thurso Posts: 73 ![]() ![]() ![]() |
So the tyre on at Moment is 110v so tyre is suited for rrs, only thing wrong is the wall size,Its 45 and Not 40, and fact Its a poor tyre, corrrct or Not. Haha Yeh dont think thats why it was locked but will watch were i Post. 2007 V8 HSE RRS STORNAWAY GREY |
"Y" is the speed rating, "106" is the load rating. No need to whistle. As it happens, the speed rating is actually the maximum speed at which the tyre will run whilst its carrying maximum load. By specifying a higher speed rating you effectively add a factor of safety. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
If it's marked as 110V then it would seem to be ok. Does it have "XL" or "reinforced" on it too? The aspect ratio is taller than specified by LR but that's only a problem if you need to make a warranty claim - they might use it as an excuse to void a warranty claim relating to suspension. Other than that, it changes the gearing slightly. Some people run a taller ratio on 20s in order to improve the ride quality but also because they are cheaper than the correct tyres. I run 55 instead of 50 on my 19s but that's only because Pirelli don't make the ATR in 50 ratio. I never fit cheap tyres - a false economy in my opinion. I shouldn't worry about posting in the wrong section - most new posters seem to these days and anyway, threads often seem to degenerate in to wibble... 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Yes - LR did limit the speed due to tyre safety - basically to give you safe operation, rather than the tyres being unsafe Mike 2014 Facelift Discovery |
Do like this forum. Learn something useful virtually every day |
Yeh they have reinforced on them, not too happy about wrong aspect ratio, will be contacting garage I bought from to see what they saying about it.... |
