Intermittent parking sensors
Hi can any one help, the parking sensors work sometimes and then other times they don't. What could be causing this .Thanks for any help .
Tue May 21 2013 9:57pm
PEACHY
Is there a error message ? if so definately a sign they or at least 1 is on the way out what year RRS. Ideally a diagnostic reading should identify the offending location. Bodsy ( site sponsor ) read mine - he was spot on. 16MY Estoril Blue SVR.............
14MY Autobiography Dynamic - SDV6 - Fuji White
Tue May 21 2013 10:17pm
flydive
I have the same problem with mine
Sometimes they were working, sometimes I had a long beep and then the flashing light in the switch.
I traced mine to a broken wire on one of the sensors, sometimes it made contact, sometimes not, now is completely out, I haven't got around repairing it yet.
To check which sensor is, put the car in reverse with the ignition on, parking brake off, then go around the car and listen to the sensors, they should make a "tic tic tic" noise, the silent one is the one giving problems.'08 RRS TDV8
Thu May 23 2013 8:36am
Zippy
Thank you for your replies i will check it out.
Thu May 23 2013 6:42pm
SkyWalker
Make sure your seatbelt is on, otherwise the seatbelt off warning sound has priority over the parking sensor sound.
Happened to me in the parking garage... SW
Sometimes it is not enough to do our best;
sometimes we must do what is required.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
