Home > Faults & Fixes > Battery replacement in key fob for RRS 2008
samps72
England 2008 Range Rover Sport TDV6 HSE Santorini Black
Hi all,
My spare key doesn't unlock, it will lock the doors after I've driven using the key but when I try to unlock straight away..... Nothing!
I suspect the battery is poorly, but I may be wrong
Is it worth trying to change the battery or just bite the bullet and order a new key from LR ������� Shocked Crying or Very sad RRS 2.7 HSE TDV6 2008
Black
Ivory leather
RSE
Supercharged wheels
Privacy glass
R32 gone
330i BMW gone
A3 Sportback 170 Quattro sline gone
Post #383645 Mon May 20 2013 10:43pm
Montythegod
United Kingdom 2006 Range Rover Sport Supercharged Rimini Red
I replaced the battery in mine... there are several how to's on google (in a hurry or i'd post a link)
Prise open the existing key, desolder the existing battery and resolder a new one, glue casing back together ! cost me �5 for the battery from ebay Smile
They charge wirelessly when in the car, and like any Nicad battery fail eventually Sad Why?.. Because i can....
RRS 2006 S/C Rimini Red Weekend toy
Subaru impreza 1998 2.0 340hp still here
Smart car 0.7 61 hp Carbon offset
Sierra cosworth 2.0 350 hp GONE
Various RS escorts, Vauxhall sri's Volvo T5's, BMW 3 series, fiestas (?) fiat's....
Mr Mischief - www.mischief-inc.co.uk Wink
Post #383653 Tue May 21 2013 8:19am
samps72
great advice Monty
Do you have the battery details? be handy to know before I start to open the case
Cheers RRS 2.7 HSE TDV6 2008
Black
Ivory leather
RSE
Supercharged wheels
Privacy glass
R32 gone
330i BMW gone
Post #383657 Tue May 21 2013 8:44am
Markos
Slovenia 2008 Range Rover Sport TDV8 HSE Java Black
Samps you should find all the details here http://www.disco3.co.uk/forum/topic63124.html
Markos 2008 RRS TDV8 HSE, Java black, Alpaca,.....
Post #383660 Tue May 21 2013 9:52am
samps72
Thanks Markos
Battery ordered, watch this space Neutral Thumbs Up RRS 2.7 HSE TDV6 2008
Black
Ivory leather
RSE
Supercharged wheels
Privacy glass
R32 gone
330i BMW gone
Post #383682 Tue May 21 2013 2:53pm
Paddi
samps72 wrote:
Thanks Markos
This link has a few pictures and other tips that I found helpful when doing mine:
http://www.disco3.co.uk/forum/topic39609.h...ey+battery
Had a bit of a struggle with desoldering the old battery but despite getting it pretty hot and generally rough handling the PCB it still works so must be tougher than it looks.
Good luck Thumbs Up 2008 MY Java Black TDV8 HSE
Post #383690 Tue May 21 2013 4:46pm
samps72
Thanks all for your words of wisdom
Will let you know how I get on Confused RRS 2.7 HSE TDV6 2008
Black
Ivory leather
RSE
Supercharged wheels
Privacy glass
R32 gone
330i BMW gone
Post #383727 Tue May 21 2013 11:00pm
samps72
As promised here's the outcome of my key fob battery replacement!
The hardest part was opening the key fob to access the battery! the two halves were well and truly stuck together. I kinda new this might be an issue so I ordered a replacement fob from ebay, but wish I hadn't. The replacement fob was very poor quality and didn't fit together as well as the original so I ended up glueing the original key back together.
Soldering the battery was quite fiddly but if you have a steady hand you should be fine. Had to order the battery from Ebay as no local stockists had them in stock, they could have ordered them in but would of cost more than ordering on ebay. New batt was delivered within a few days.
So total cost, including the useless key fob I ordered ��22.00 a little better that �150 from LR
Thanks for everyones advice on this, much appreiciatted
Thumbs Up Thumbs Up Thumbs Up RRS 2.7 HSE TDV6 2008
Black
Ivory leather
RSE
Supercharged wheels
Privacy glass
R32 gone
330i BMW gone
Post #384405 Fri May 31 2013 10:24am
Paddi
Well done. Nothing more satisfying than a bit of DIY that works and saves you serious cash. Another great example of how the forum benefits RRS owners. Thumbs Up 2008 MY Java Black TDV8 HSE
Post #384486 Sat Jun 01 2013 8:26pm
Nigex4x4
United Kingdom 2006 Range Rover Sport TDV6 HSE Arctic Frost
Only gone and done it
Hi guys
Just a big thank you to the forum as ever - saved me a bundle and taught me some new tricks.
Hardest part was opening the fob as has been said many times, the biggest plus was that I knew it could be done and so I didn't give up when it seemed utterly impossible.
Best advice I can now share is about opening the fob...
I used a very sharp craft knife a very blunt dinner knife and a very pointy very sharp multi-tool knife.
Start by flicking the key blade out as if you were going to pop it in the ignition
Next use the craft knife to draw a line in the sealed seam around the whole of the fob, this is to give you an 'in' with the sharp and pointy blade
Carefully and ensuring that the sharp pointed blade goes no further in than about .5cm use it to stab into the seam all along behind where the key sits when closed gradually you should then be able to get the strong dull dinner knife blade in and get some leverage
Now do the same at the top of the fob next to the key blade and work your way down the side of the fob
be very patient, keep prying the halves apart until you get a significant gap and work on it until you can pry the whole thing apart.
I can't add anything to what has already been said about the rest of the operation except putting it back together again where I used super glue all around the join once it was assembled, then I sat there for a few minutes till it set.
I didn't expect it to work, I am not a soldering type of guy (unless it's copper tube) But it did and I am absolutely capped.
Thanks again guys
Nige Bow down
Post #447078 Thu Jan 01 2015 10:15pm
Paddi
Thumbs Up Very Happy 2008 MY Java Black TDV8 HSE
Post #447162 Fri Jan 02 2015 4:02pm
Gornal Hills
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
What's the life span (approx) of the battery ?? 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #447166 Fri Jan 02 2015 4:33pm
