![]() | Home > Technical > Drivers Door Lock |
dataman Member Since: 21 Mar 2011 Location: Burgess Hill Posts: 5 ![]() ![]() ![]() |
Is it just me |
Common problem. The electrically powered latch mechanism just seems to lose it's mojo. If you are comfortable with DIY then follow the guide on our sister site here: http://www.disco3.co.uk/forum/topic33743.html?highlight= The new latch used to cost about £40 but think it's just gone up to about double that as another example of LR's 'can't care less' attitude to it's customers. Dealer shouldn't charge you more than 1-2 hours labour as it is not that difficult just a bit fiddly. 2008 MY Java Black TDV8 HSE ![]() |
I have a LR extended warranty - just wondered if it might be covered? (Or just wear & tear)? |
It should be covered. Mine was. |
Popping down to my local Harwoods in Hove on Friday - they say it's covered too. Maybe they can fix the sunroof as well when It's with them as well - just stopped working - even the 20 second reset thing - doesn't!! |
Visited Harwoods in Hove this morning - they're ordering a new door latch (an intermittent fault) for fitting next week & have reset the sunroof AND after a plug into the 'system' have pointed out the the EGR Valve needs replacing - all under my Extended Warranty. - Well done Harwoods - nice customer service!! |
