Home > Maintenance & Modifications > Squeaking dash |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 |
What year is your RRS? 2014 L405 SDV8 RR Autobiography
Sat May 18 2013 7:36pm |
Simon_scott_wilson Member Since: 18 May 2013 Location: Worcester Posts: 8 |
2008 2.7 v6 HSE Newbie |
Sat May 18 2013 7:49pm |
Saeedasghar Member Since: 10 Dec 2012 Location: Worcester Posts: 104 |
M and m 4x4 on the way to droitwich mate if you head round the back of the sales forecourt. The service section at the back has very clued up and friendly staff. Went there to pick there brains on few things always come through with relevant information. |
Sat May 18 2013 8:27pm |
That's great thanks.....i'll look them up and see if they'll come for a ride and witness the noise. It's doing my head in; the car is amazing but the constant creak on anyhting but perfectly flat roads is reeally spoiling the experience! Newbie |
Sat May 18 2013 8:43pm |
See here...
Sun May 19 2013 2:19am |
Thanks Bobby. Doesn't sound like it's an easy one to fix! I presume fitting the squeaks and rattles kit is a dash out job? Has anybody ever posted a guide to removing and replacing the dash or top cover? Newbie |
Sun May 19 2013 9:48am |
Basically the kit consists of various antifrictions gels for the different type of plastics used in the vehicle. There is also lubricant, rubber seal coating and light grease for mechanical components. Included are foam and PTFE tapes.
Sun May 19 2013 11:50am |
That's brilliant advice. Thanks for your help guys.....i'll let you know the outcome! Newbie |
Sun May 19 2013 10:07pm |
USAFBuckeye Member Since: 24 Feb 2013 Location: Il Posts: 60 |
Just tried to buy one of the kits here in the states...$435.00!
Wed Aug 14 2013 4:07am |
wakey Member Since: 24 Dec 2014 Location: Preston, Lancashire Posts: 6 |
Hi All, I know this thread is getting on a little but I too had the same problem. Tried tape around the fixings of the speaker/Felt pads under the speaker cover etc etc. Finally........took off the speaker cover and drowned the joint between the upper and lower dash with Halfords 'dry PTFE' lubricant (£4.99). Seems to have worked a charm!!! No creak/rattle/squeak any more . Hope this helps somebody else. BHP is how fast you hit the wall, torque is how much of the wall you take with you.......... |
Thu Jan 15 2015 10:47pm |
