![]() | Home > Maintenance & Modifications > Squeaking dash |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 ![]() ![]() ![]() |
What year is your RRS? 2014 L405 SDV8 RR Autobiography |
Simon_scott_wilson Member Since: 18 May 2013 Location: Worcester Posts: 8 ![]() ![]() ![]() |
2008 2.7 v6 HSE Newbie |
Saeedasghar Member Since: 11 Dec 2012 Location: Worcester Posts: 104 ![]() ![]() |
M and m 4x4 on the way to droitwich mate if you head round the back of the sales forecourt. The service section at the back has very clued up and friendly staff. Went there to pick there brains on few things always come through with relevant information. |
That's great thanks.....i'll look them up and see if they'll come for a ride and witness the noise. It's doing my head in; the car is amazing but the constant creak on anyhting but perfectly flat roads is reeally spoiling the experience! Newbie |
See here...
Thanks Bobby. Doesn't sound like it's an easy one to fix! I presume fitting the squeaks and rattles kit is a dash out job? Has anybody ever posted a guide to removing and replacing the dash or top cover? Newbie |
Basically the kit consists of various antifrictions gels for the different type of plastics used in the vehicle. There is also lubricant, rubber seal coating and light grease for mechanical components. Included are foam and PTFE tapes.
That's brilliant advice. Thanks for your help guys.....i'll let you know the outcome! Newbie |
USAFBuckeye Member Since: 24 Feb 2013 Location: Il Posts: 60 ![]() ![]() ![]() |
Just tried to buy one of the kits here in the states...$435.00! |
wakey Member Since: 24 Dec 2014 Location: Preston, Lancashire Posts: 6 ![]() ![]() ![]() |
Hi All, I know this thread is getting on a little but I too had the same problem. Tried tape around the fixings of the speaker/Felt pads under the speaker cover etc etc. Finally........took off the speaker cover and drowned the joint between the upper and lower dash with Halfords 'dry PTFE' lubricant (£4.99). Seems to have worked a charm!!! No creak/rattle/squeak any more |
