Home > General > Range Rover Gone Bang |
oxford-boy Member Since: 10 Nov 2011 Location: Oxford Posts: 148 |
Are you using Warranty Direct for this job? 2005 Range Rover Sport TDV6 HSE in Artic Frost. 20" 2010 HST Alloys, sidesteps, Hawke tips, plus minor bits and bobs along with a remap. Four spike spiders ready for the Alps again now tucked up in their garage boxes... |
Mon Apr 29 2013 12:51pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4403 |
Dragon Engines, another "re-conditioning" specialist |
Mon Apr 29 2013 2:14pm |
At least the warranty co have agreed to foot the bill Bodsys Brake Bible
Mon Apr 29 2013 5:29pm |
I just wonder - if, - in the future, there should an engine problem would Warranty Direct have indigestion because the car's history showed that it had not been repaired by Land Rover ! |
Mon Apr 29 2013 6:03pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Wouldn't think so as this appears to be their approved repairer 2x TDV6. SE and HSE. Both returned to sender with issues👀
Tue Apr 30 2013 6:59am |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
I am going to book my car in for a new oil pump, is there anything else that I need to change whilst the front of the car is stripped down??? It had new cam belt 12 months ago. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures Gone - A couple of RRS, A couple of Disco's. However thinking of another Sport. |
Mon May 06 2013 11:46am |
You could change the water pump which you need to remove the timing belt to do anyway. Istr water pump is about £70 Bodsys Brake Bible
Mon May 06 2013 11:54am |
Do no harm to replace the belt again either. Doesn't do them any good being under tension then removed and refitted. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Mon May 06 2013 12:14pm |
Prior to booking my car in for the updated oil pump, can I just re confirm that the pump I need is the one fitted to the 3 litre engine - the latest version being LR013487. Also as the car has only covered 35k, is it worth changing the water pump? In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures Gone - A couple of RRS, A couple of Disco's. However thinking of another Sport. |
Wed May 08 2013 12:14pm |
there is one for pre 06A99999 1348651
Wed May 08 2013 12:25pm |
Latest type oil pump now fitted by main dealer €400 all in |
Wed May 22 2013 1:09pm |
not a bad price at all Bodsys Brake Bible
Wed May 22 2013 1:29pm |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 |
Did you get any other bits changed at the same time? 2014 L405 SDV8 RR Autobiography 2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone 2007 RRS TDV6 HSE - Zermatt Silver - Gone |
Wed May 22 2013 4:04pm |
