Home > General > Number plate fixings |
Most L/R dealers use double sided sticky tape which is very strong, might be worth calling into your local dealer and talk nicely to them. |
Fri May 03 2013 9:39am |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
If put on properly, you'll have no problems with stuck on plates.
Fri May 03 2013 9:53am |
sparky8181 Member Since: 02 Nov 2012 Location: West Midlands Posts: 588 |
+1 on the 3m tape, this stuff is seriously strong. |
Fri May 03 2013 11:02am |
Corns-88 Member Since: 20 Feb 2013 Location: cheshire Posts: 26 |
I bought a pack of double sided sticky pads from Halfords. They kept the plate on my trailer for 3 years no problems 07 tdv8 stornoway grey at home tucked up
Fri May 03 2013 12:02pm |
It's necessary to use the thick sticky pads for the rear plate because the fixing holes thoughtfully provided by LR have plastic plugs in them to receive fixing screws and these plugs protrude above the surface by a couple of mm.
Fri May 03 2013 1:07pm |
Mark David Member Since: 03 May 2013 Location: Northampton Posts: 6 |
Thanks everyone, I took Ady's advice and popped down to my local dealer who handed me a load for nothing. A real mess behind the plate that came off though, it took me about 30/40 mins just to get all the original tape off, clean and prepare before I could fit the new one.
Sat May 04 2013 6:37am |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 |
What did you use to remove the old sticky pads?
Sat May 04 2013 8:23am |
I'm sure you will end up paying for them sooner or later |
Sat May 04 2013 8:40am |
I used a label remover fluid as it doesn't harm the paintwork. I kept soaking them allowing time for it to attack the old adhesive then with a hand towel (which the Missus didn't appreciate) I just kept rubbing away in small circles and it progressively gets easier as it loosens. |
Sat May 04 2013 8:58am |
Ain't that the truth!! |
Sat May 04 2013 8:59am |
I would agree that the sticky pads are the best method to connect the plate. I would avoid screwing any plate in now.
Sat May 04 2013 10:13am |
a13xbb Member Since: 07 Mar 2013 Location: Kent Posts: 121 |
Sadly on removal of my number plate it revealed two drilled holes!!!! Why would you do it |
Sat May 04 2013 1:40pm |
I've just bought some 'sticky stuff remover' from Lakeland Plastics. I'm going to give it a go today & will post the results later.
Sun May 05 2013 9:46am |
TonykRRS Member Since: 30 Jul 2013 Location: London Posts: 7 |
Hi all, I'm a bit late to this discussion, but just in case, like me, sticky pads really are not the answer, you can buy the hexagonal plugs, known as nut-blindanchors, from Paddock Spares for 65p each + postage.
Sat Oct 19 2013 11:26am |
