![]() | Home > General > Number plate fixings |
Most L/R dealers use double sided sticky tape which is very strong, might be worth calling into your local dealer and talk nicely to them. |
If put on properly, you'll have no problems with stuck on plates. |
sparky8181 Member Since: 02 Nov 2012 Location: West Midlands Posts: 588 ![]() ![]() |
+1 on the 3m tape, this stuff is seriously strong. |
Corns-88 Member Since: 20 Feb 2013 Location: cheshire Posts: 26 ![]() ![]() ![]() |
I bought a pack of double sided sticky pads from Halfords. They kept the plate on my trailer for 3 years no problems 07 tdv8 stornoway grey at home tucked up
It's necessary to use the thick sticky pads for the rear plate because the fixing holes thoughtfully provided by LR have plastic plugs in them to receive fixing screws and these plugs protrude above the surface by a couple of mm.
Mark David Member Since: 03 May 2013 Location: Northampton Posts: 6 ![]() ![]() ![]() |
Thanks everyone, I took Ady's advice and popped down to my local dealer who handed me a load for nothing. A real mess behind the plate that came off though, it took me about 30/40 mins just to get all the original tape off, clean and prepare before I could fit the new one.
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 ![]() ![]() ![]() |
What did you use to remove the old sticky pads?
I'm sure you will end up paying for them sooner or later ![]() ![]() |
I used a label remover fluid as it doesn't harm the paintwork. I kept soaking them allowing time for it to attack the old adhesive then with a hand towel (which the Missus didn't appreciate) I just kept rubbing away in small circles and it progressively gets easier as it loosens. |
Ain't that the truth!! |
I would agree that the sticky pads are the best method to connect the plate. I would avoid screwing any plate in now.
a13xbb Member Since: 07 Mar 2013 Location: Kent Posts: 121 ![]() ![]() |
Sadly on removal of my number plate it revealed two drilled holes!!!! Why would you do it |
I've just bought some 'sticky stuff remover' from Lakeland Plastics. I'm going to give it a go today & will post the results later.
TonykRRS Member Since: 30 Jul 2013 Location: London Posts: 7 ![]() ![]() ![]() |
Hi all, I'm a bit late to this discussion, but just in case, like me, sticky pads really are not the answer, you can buy the hexagonal plugs, known as nut-blindanchors, from Paddock Spares for 65p each + postage.
