Home > General (L494) > Engine sizes |
Arent there ultimately going to be 4/5 engine derivitives:
Fri May 03 2013 8:02am |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
As I read it, V8 petrol and v6 diesel at release. SDV8 will become available "at some point" 2x TDV6. SE and HSE. Both returned to sender with issues👀
Fri May 03 2013 8:18am |
Is it the V8 rumble you are after? Because i'm sure the V6 will go quick enough having shed nearly 500kg off the weight of the new sport. |
Fri May 03 2013 8:46am |
Think I'm going to need to drive an SDV6 then. It's the lack of drama V8 gives towing that I need. Just spoke to LR and SDV8 will be available from Januaryish.... Possibly with an extra cog in the box over the 8 speed. Prices are bit bloody scarey though 2x TDV6. SE and HSE. Both returned to sender with issues👀
Fri May 03 2013 8:53am |
With the new sport being lighter, is that going to compromise its towing capability? |
Fri May 03 2013 8:56am |
Doing the maths backwards, that makes new car 2.2 tonnes which will be fine as long as my caravan doesn't put any weight on. Car trailer will be marginal if towing a big car but at least it takes it all below 3.5 tonne flag. Been stopped several times and Vosa and police had issues with combined weights. Only up side is I have Class 1 licence so issue has dissolved. New towing rules are hard to keep up with and tacho laws even more complicated. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Fri May 03 2013 9:08am |
New sport retains the land rover 3.5t max towing capability
Fri May 03 2013 9:20am |
corrisgrey Member Since: 13 Apr 2013 Location: West Sussex Posts: 145 |
The new SDV8 FFRR is £6800 more than the the equivalent model with a SDV6. I would be surprised if there wasn't the same difference in the RRS.
Fri May 03 2013 10:09am |
DPF isnt really an issue at all
Fri May 03 2013 10:20am |
Pleased to hear that as I has PDF issues with both my SDV6 XF's in 2008 and 2010. Perhaps the regeneration system has been improved. |
Fri May 03 2013 10:29am |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Not had any DPF issues on my SDV6 here and I'm 18 months into ownership.....runs off to touch wood ON THE WAY: BMW F21 M140i
Fri May 03 2013 10:35am |
On my 2011 and so far on my 2013 no DPF issues Mike
Fri May 03 2013 11:16am |
eew RRS gone Audi SQ5...Gone Audi Q7 S-Line 240 3.0TDI Gone Audi A6 Allroad Sport 270 3.0TDI |
Fri May 03 2013 1:21pm |
he was blatant to... Mike
Fri May 03 2013 1:46pm |
