Home > Technical > rrs 2005 se 2.7v6 suspension compressor repair
baldrik
2005 Range Rover Sport TDV6 SE Stornoway Grey
Hi all. I am a new member, on my 2005 rrs i got the warning message " normal height only" on the dash display, the garage had a look an said i need a new compressor and it would cost me about £300+labour, so i checked out this forum and found that you could get a compressor overhaul kit( Pno: jpo5000-10), i got mine from Rimmer bros. for £16.92 + p&p.
I found various posts on how to carry out this task and set about the repair. it took longer than it should have as i was unable to release the two large air lines from the head and so had to complete the repair with the compressor hanging from these air lines, all has gone ok and the suspension is now working fine with no more warnings, i will keep you updated.
Post #381801 Tue Apr 30 2013 9:06am
Paddi
Welcome. Well done. Sounds like a good job - if you have any pictures post them up with a few notes on the 'how to thread'?
Cheers, 2008 MY Java Black TDV8 HSE
Post #381806 Tue Apr 30 2013 9:48am
