Home > Technical > Hand Brake Light Flashing |
Landlord Member Since: 26 Sep 2006 Location: Hampshire Posts: 607 |
Since the Assurance Programme and all the updates I occasionaly have the handbrake light flashing first thing in the morning along with a beep, beep, beep from the dash board. Doesnt seem to be a pattern to when its going to do it other than occasionaly frist thing, after starting engine and before pulling away. Outside temp was 7 degrees this morning so not an ice warning. Whilst light is flashing, lift electronic brake lever and flashing stops, sound stops.
Sat Apr 24 2010 4:06pm |
dric0327 Member Since: 07 Jan 2010 Location: Mansfield Posts: 59 |
Hi Landlord - i get the same thing in mine - never noticed the park brake fault. Just beeps and flashes for a few seconds. Not done it since it's been warmer though. I'll keep a check on it to see if it happens again and if the dashboard says anything.
Sun Apr 25 2010 6:14pm |
8 CDC Member Since: 21 Apr 2010 Location: Sth Lanarkshire Posts: 59 |
Ive actually just come on to post a question re the same fault......
Sun Apr 25 2010 7:39pm |
I have not noticed the park brake fault message either. The flashing hand brake and warning sound happens occasionaly, Think it might be conected to outside temperature over night but probably clutching at straws. Will be going in next month for some more updates, not recalled but might as well have software updated with latest updates. Whilst there they can check the brake system.
Sun Apr 25 2010 9:39pm |
sregnif Member Since: 18 Jun 2011 Location: Clackmannanshire Scotland Posts: 3 |
I had the same error last winter, parking brake red light comes on, then the fault light comes on to tell me I have a fault. I had it for a few of the coldest months last year, then by April it disappeared, Low and behold it returned in December and hasn't gone yet. Incidentally I've changed the front Diff 40K miles, Alternator and battery all within the space of a month..
Thu Apr 18 2013 12:29pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4417 |
I have seen a few wiring issues on 06MY's. All logging a switch fault
Thu Apr 18 2013 1:05pm |
theGeMan Member Since: 17 Dec 2014 Location: Sussex Posts: 10 |
I had the same thing on mine today,
Sun Jan 04 2015 10:26pm |
Ovey Member Since: 21 Jan 2015 Location: Portsmouth area Posts: 80 |
For the last 3 days I've started getting the red flashing light and "Park brake fault" showing on the dash too. It's not first thing in the morning when I leave for work, it's when I get in my car to come home! I also had it this lunchtime when I had to nip out from work.
Thu Feb 12 2015 1:34pm |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 |
[quote="Landlord"]Since the Assurance Programme and all the updates I occasionaly have the handbrake light flashing first thing in the morning along with a beep, beep, beep from the dash board. Doesnt seem to be a pattern to when its going to do it other than occasionaly frist thing, after starting engine and before pulling away. Outside temp was 7 degrees this morning so not an ice warning. Whilst light is flashing, lift electronic brake lever and flashing stops, sound stops.
Thu Feb 12 2015 1:50pm |
itisme |
Thu Feb 12 2015 2:00pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Wheel arch wiring? Visiting from DISCO3.CO.UK 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver |
Thu Feb 12 2015 3:26pm |
Ah, ok. I'll try to take a look at the weekend then. Thanks for the heads up! Current: Range Rover Sport 3.0 TDV6 HSE in Stornoway Grey
Thu Feb 12 2015 4:12pm |
I found the connectors in the NSR wheel arch and checked all the wires into them (and the smaller connector in the OSR wheel arch too) - all seemed tight, and the cable loom coming away from it has been wrapped in tape and seems sound. I then gave the connectors a firm push together (despite them seeming fine when I checked). Since then I've not (yet?) had the fault repeat so maybe the connector had just parted enough to give a spurious indication?
Tue Feb 17 2015 9:12am |
Hopefully, that was it. Visiting from DISCO3.CO.UK
Tue Feb 17 2015 9:36am |
