Home > Maintenance & Modifications > Air Suspension Fuse Blowing
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
Evening, my air suspension fuse has blown twice approx two weeks apart, not showing a fault apart from electrical problem i.e blown fuse. Does anyone have an idea what may be causing the fuse to blow?
Post #380776 Wed Apr 17 2013 9:45pm
Bodsy
Site Sponsor
Is it constantly running (except when the fuse has blown of course) check the relay as they are known to stick when they are reaching end of their life. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #380782 Wed Apr 17 2013 10:39pm
1JBS
Thanks Bodsy new relay fitted as per your previous suggestions, ran ok for nearly 2 weeks and then blew again, I have a new AMK compressor ready to go on. Can the motor on the compressor cause the fuse to blow? Thanks...
Post #380789 Thu Apr 18 2013 7:14am
Disco_Mikey
Yes, a dead/dying compressor can also cause the fuse to blow Thumbs Up
Post #380796 Thu Apr 18 2013 8:02am
1JBS
Many thanks all, just checked the fuse and it is OK, so the system must have locked out for some reason? Need to get it on a diagnostics system. It is now working normally since taking the fuse out, but for how long ?
Post #380800 Thu Apr 18 2013 9:15am
Autobiography Conversion
Could be water within the compressor itself. If so then the dryers gone and needs to be replaced. To check just remove the compressor/pump and check for water inside if it's got some water in it then the dryers at fault and needs to be changed. Hopefully that should stop the fuse going.
Post #383150 Wed May 15 2013 2:15pm
1JBS
Thanks, ended up replacing the compressor for a new AMK and upgraded the software all working well now, brilliant service from Frogs Island http://www.frogsisland4x4.com/ Thumbs Up
Post #383175 Wed May 15 2013 4:57pm
Nice to hear that got sorted. I just had mine done last week, my suspension was taking forever to raise and then just ended up in load mode. Yellow suspension failure light came on also. Got the part from Lookers in Park Royal and had it fitted - works fine now.
Post #383207 Wed May 15 2013 11:16pm
