![]() | Home > Technical > Parking sensors |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
Mine was temperamental during the winter and I had the same fault intermittently, but this hasn't come up since the warmer weather.
K80tcg Member Since: 29 Mar 2013 Location: Verwood Posts: 25 ![]() ![]() ![]() |
Have you unplugged just the front or the back from the control unit.
consort Member Since: 25 Mar 2012 Location: uk Posts: 21 ![]() ![]() |
Many thanks.
Do a continuity test on each wire, failing that you may need to plug the car in to see what the fault code is Tdv8 range rover sport
yes thanks, that would be the next step as getting that bloody bumper off is a right pain! |
