Home > Technical > Parking sensors
consort
2006 Range Rover Sport Supercharged Java Black
Parking sensors
My parking sensor problem has returned on my RRs supercharged.
My dash has a warning saying front parking sensors not operational. I checked them all for clinking and found them to be ok. I had two new as spares and so I replaced them all systematically, but all to no avail. I also had a spare control module that I swopped over but that did not work either?
Any ideas please?
Thanks
Post #380568 Tue Apr 16 2013 2:22pm
Bradders
Mine was temperamental during the winter and I had the same fault intermittently, but this hasn't come up since the warmer weather.
There is a known problem with the wiring behind the front bumper. FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
Ex 2016 135i M Sport - dream car
Ex 2003 RS6 Avant - piece of cr*p
Ex 2014 320d X Drive, M Sport Touring - ok I guess
Ex 2007 RRS TDV8 - bloody loved it
EX 2007 FL2 XS - not so bad
Post #380604 Tue Apr 16 2013 5:18pm
K80tcg
England 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Have you unplugged just the front or the back from the control unit.
So at least you can see where the fault is.
There is some good advice on you tube
 Tdv8 range rover sport
911 turbo s
BMW GS1200 A
Post #380606 Tue Apr 16 2013 5:24pm
consort
Many thanks.
I have tried these fixes, but still to no avail. I may look a bit closer into the wiring loom.
Post #380752 Wed Apr 17 2013 6:51pm
K80tcg
Do a continuity test on each wire, failing that you may need to plug the car in to see what the fault code is Tdv8 range rover sport
911 turbo s
BMW GS1200 A
Post #380754 Wed Apr 17 2013 6:59pm
consort
yes thanks, that would be the next step as getting that bloody bumper off is a right pain!
Post #380755 Wed Apr 17 2013 7:03pm
