Home > General > Improved MPG - TDV8
simple1
"Currently the combination of diesel and LPG may cause great increases in power output and mechanical problems. We therefore do not convert diesel run vehicles. However should a system be proven to run efficiently and be mechanically reliable with the same environmental benefits, then LPG Conversions Limited will carry out the relevant checks before agreeing to carry out installations"
As taken from top LPG converters web site. Whistle I believe bio gas is the conversion used for diesels which is something different and mostly made from s-h-I-t-e and household waste so methane basically. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #379465 Tue Apr 02 2013 10:38pm
cossiedave
England 2006 Range Rover Sport TDV6 Autobiography Zambezi Silver
i moted a mondeo diesel the other day that had been converted to gas, i asked him if he could convert my tdv8 and he said yes, the company was called eco-max drt Thumbs Up
Post #379471 Wed Apr 03 2013 6:16am
jack.bauer
Paddi wrote:
Well it seems despite my (and others) scepticism the MPG is genuinely improved.
Just calculated the actual consumption over a 360 odd mile trip at the weekend using the time-honoured method of brimming the tank at the beginning of the journey, re-setting the trip meter and then brimming the tank again at the end of the trip.
And the answer is....... 26.54 MPG which compares favourably with the 21.6 MPG the car was returning before the MAP cleaning and adding Millers magic additive.
The computer dash display of average MPG was pretty constant at 29.0 to 28.8 which again compares favourably with previous average readings of about 23.5, but proving once again that the computer is a bit optimistic.
The journey was almost all motorway and 'A' roads so just cruising at 70 - 75 (we weren't in a hurry) with no hold ups at all.
I was hoping for slightly better economy but then I was with my mate who is bit of a lard-arse so I'm blaming him for the slightly worse economy!
Interesting. Will be trying out for sure and report back 07 TDV8 + BAS map
Post #379749 Sat Apr 06 2013 10:21am
I'm just checking Paddi
Did you mean you cleaned the MAF sensors?
I'm not sure what a MAP sensor is.
I'm going to buy some MAF cleaning spray this weekend and give mine a blast. RRS gone
Post #379918 Tue Apr 09 2013 7:46am
Paddi
AWD - no it was the MAP sensors (manifold absolute pressure). Planning to clean the MAF sensors (mass air flow) too but so far failed to find out how to get them out Rolling with laughter If you figure it out please post how you did it. 2008 MY Java Black TDV8 HSE
Post #379924 Tue Apr 09 2013 8:14am
The MAFs can be cleaned by just removing the air box cover and the 2 pipes to the inlet manifold.
Then the mafs are easily accessed within the air box cover molding. RRS gone
Post #379978 Tue Apr 09 2013 4:22pm
Paddi
Thanks. Was thinking had to pull them out somehow but what you say makes sense Rolling Eyes . Just need to get some electrical contact cleaner stuff (£3.99 from Halfords). 2008 MY Java Black TDV8 HSE
Post #379979 Tue Apr 09 2013 4:58pm
