Home > General > Improved MPG - TDV8
Paddi
Improved MPG - TDV8
My TDV8 seemed to have slightly worse fuel economy than others have reported. Calculated mpg by brimfull to brimfull is about 21.6 and I've never seen much better than 23.5 average on the dash computer. So after cleaning the MAP sensors I bought some Miller's Diesel Power Eco Max and put 100 mls in a half full tank, brimmed it and re-set the 'mpg-ometer-. Now I don't generally believe in magic additives but a lot of people have said this stuff is actually good at cleaning the engine.
Next day 30 miles into a motorway trip it was reading 28 mpg and over the whole 200 mile round trip at mostly 70 mph or above (with a few full throttle accelerations once it was thoroughly warmed up to get the turbos working Cool) it was showing 28.8 average on the dash Shocked
So an improvement of just over 20% Thumbs Up
For the cost of 100mls at about £2.70 that seems useful. Or am I just kidding myself? 2008 MY Java Black TDV8 HSE
Post #377975 Sat Mar 23 2013 5:38pm
simple1
Millers stuff is good. I wouldn't use any other additive in my Audi and their engine oil designed for classic minis is well known to preserve engines that share oil with gearboxes.
Sound like you have had an issue as mine would sit at 70-80 and return high 20's without bother and mid 20's towing a 27 ft caravan and I have a heavy right foot Whistle 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #377980 Sat Mar 23 2013 6:11pm
mjbrr
United Kingdom 2009 Range Rover Sport TDV8 HSE Santorini Black
I drive mine conservatively and struggle to get 23 with 80% A road driving
Might try the sensor clean. 2009 3.6 TDV8 HSE Santorini Black
Post #377982 Sat Mar 23 2013 6:16pm
Paddi
That does sound very similar to mine before I started fiddling with it. Hopefully you saw my post today about how to find and clean the MAP sensors. If the car wasn't under a blanket of snow I'd be out there cleaning the MAF sensors - which is the next thing to try. 2008 MY Java Black TDV8 HSE
Post #377984 Sat Mar 23 2013 6:24pm
BulletProofBomb
I got better MPG with a BAS remap Very Happy But cant keep my right foot off the pedal cause of the grin factor so MPG back down below where I started Sad Good if you can drive sensibly. RRS TDV8 (loving it)
Suzuki Bandit 1200 (For when the suns out)
Nissan 350z GONE
Post #378008 Sat Mar 23 2013 11:54pm
cossiedave
England 2006 Range Rover Sport TDV6 Autobiography Zambezi Silver
i have just put some forte diesel cleaner in mine and also put some egr cleaning throuhg it, might try cleaning my sensors next as i am always looking at ways to improve my mpg
Post #378033 Sun Mar 24 2013 2:00pm
jack.bauer
Re: Improved MPG - TDV8
interesting. and you are confident the reading is accurate i.e you've actually got more miles out of the same tank?
Post #378038 Sun Mar 24 2013 2:59pm
Paddi
It's a fair question. The computer is definitely showing the best average mpg I've seen. The computer is probably a bit optimistic but next time I fill up will calculate the actual consumption. Be surprised if it is not better than 21.6 which I was getting before cleaning the MAPs and putting Millers in the tank 2008 MY Java Black TDV8 HSE
Post #378110 Sun Mar 24 2013 10:49pm
jack.bauer
i'll be watching this space for news.
ive just taken delivery of my TDV8. just finished a full tank with 400 odd miles, 90% motorway miles. trip reads 25mpg. im going to run another two tanks full of town driving and mixed driving before trying this. take it you just followed the instructions on the back of the bottle?
Post #378148 Mon Mar 25 2013 9:34am
Paddi
Jack, Should be using the rest of the tank this week on a long motorway run and will calculate on that. The Millers instructions are 50 mls to 50 litres or twice that if you want a quicker clean. I went for 100 mls in a full tank (84 litres). Probably worth pointing out before somebody else does that Millers is a cetane booster so may have a direct effect on mpg in addition to the indirect effect of cleaning the engine. BTW it smells very strongl and the fumes make your eyes smart Big Cry so do not keep the bottle in the car. 2008 MY Java Black TDV8 HSE
Post #378189 Mon Mar 25 2013 12:27pm
Paddi
Well it seems despite my (and others) scepticism the MPG is genuinely improved.
Just calculated the actual consumption over a 360 odd mile trip at the weekend using the time-honoured method of brimming the tank at the beginning of the journey, re-setting the trip meter and then brimming the tank again at the end of the trip.
And the answer is....... 26.54 MPG which compares favourably with the 21.6 MPG the car was returning before the MAP cleaning and adding Millers magic additive.
The computer dash display of average MPG was pretty constant at 29.0 to 28.8 which again compares favourably with previous average readings of about 23.5, but proving once again that the computer is a bit optimistic.
The journey was almost all motorway and 'A' roads so just cruising at 70 - 75 (we weren't in a hurry) with no hold ups at all.
I was hoping for slightly better economy but then I was with my mate who is bit of a lard-arse so I'm blaming him for the slightly worse economy! 2008 MY Java Black TDV8 HSE
Post #379417 Tue Apr 02 2013 2:44pm
cossiedave
i was thinking off putting my tdv8 on lpg, any one on lpg/
Post #379447 Tue Apr 02 2013 7:56pm
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
Is it even possible to run LPG on a diesel engined car? 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #379448 Tue Apr 02 2013 8:04pm
simple1
I have never heard of an LPG conversion on diesel cars. Shocked 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #379462 Tue Apr 02 2013 10:33pm
There are some systems that use a mix of LPG and diesel - I'm not sure if they're in cars yet but some lorries have been converted.
You can't just run the engine fully on LPG because LPG needs a spark to ignite it and diesels don't have spark plugs. In the LPG/diesel system, the diesel ignites as normal and this then ignites the LPG. 2012 SDV6 - it's missing a couple of cylinders
Post #379463 Tue Apr 02 2013 10:33pm
