Home > Technical > Power loss
Page 1 of 3 123>
bullet11300
Power loss
When driving to work yesterday I occasionally suffered power loss.
I was on low throttle doing 50mph when I felt like I lurched forwards as if the engine had been turned off? Within a second or two the car picked back up. A message came up on the dash but I didn't have my glasses on? It happened 3 times on a 15 mile journey. Upon returning home later that day the problem did not recur?
Any input would be appreciated. Mike
Post #379808 Sun Apr 07 2013 8:11pm
dryden1407
Scotland 2013 Range Rover Sport SDV6 HSE Luxury Fuji White
if you can't read a message on your dash then you shouldnt be driving without your glasses Shocked Shocked Shocked Shocked 2013.5 rrs black edition in white here now
Post #379810 Sun Apr 07 2013 8:21pm
bullet11300
Love forums that offer constructive feedback! Never heard of long sightedness?? If the car was anything like reliable I shouldn't need to be reading fault messages ...... Quite bad that LR have to build in 'do it yourself' trouble shooting! Mike
Post #379812 Sun Apr 07 2013 8:33pm
dryden1407
thats the most constructive feedback you will ever get in your life,,when you do have an accident,make sure your on your own 2013.5 rrs black edition in white here now
Post #379815 Sun Apr 07 2013 9:40pm
Chances are, your car will of logged the faults, so a trip to your dealer may be required to find the fault codes and get iit sorted before it breaks down completely Big Cry
Post #379816 Sun Apr 07 2013 9:55pm
Bodsy
Site Sponsor
Could just be egr valves sticking. You should have some error codes logged I would have thought Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #379817 Sun Apr 07 2013 10:01pm
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
What engine and year is your RRS? 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #379821 Sun Apr 07 2013 11:03pm
Bodsy
Site Sponsor
It's an 08 tdv8. Click on his icon Thumbs Up Bodsys Brake Bible
See it HERE
Post #379822 Sun Apr 07 2013 11:16pm
JasM
Learn something new everyday Thumbs Up 2014 L405 SDV8 RR Autobiography Cool
Post #379823 Sun Apr 07 2013 11:34pm
Disco_Mikey
Blocked fuel filter, sticky turbo, split turbo hose. Who knows Laughing
Need to have it plugged into a diagnostic computer Thumbs Up
Post #379824 Mon Apr 08 2013 5:57am
bullet11300
Cheers chaps, have got it booked in at main Land Rover dealers, will post feedback. Mike
Post #379826 Mon Apr 08 2013 6:24am
mse
What if the error message said "STOP NOW and Call assistance"? it wont have because there is no such message but still get it plugged in Mike
2014 Facelift Discovery
Post #379834 Mon Apr 08 2013 8:44am
Paddi
Re: Power loss
Well how strange. As noted on your previous thread my car not only shares the 'diff noise' with yours but also the 'momentary power loss'.
Mine does it less frequently, maybe once on a 30 mile trip and only when cruising at higher speeds - usually about 70 mph. Originally I thought it was a gearbox fault but recently started to think it is an electrical problem.
Sometimes the 'HDC not available ....' message pops up but usually there is no message.
If it happens when ACC is in use then 'Cruise control cancelled' pops up and cruise is indeed cancelled.
I've had the gearbox fluid and filter changed with no discernible difference and recently renewed the battery - again with no apparent effect.
Now I am thinking of looking into any of the sensors that can cancel cruise such as the brake pedal switch, throttle position sensor and so on.
With great respect to Bodsy and D-Mikey who both obviously know their stuff I am inclined to think it isn't anything to do with EGR valves or turbo hoses since it is just a momentary hiccup. I changed the fuel filter a few months back.
Keep us posted on the results of the dealer's investigation please. 2008 MY Java Black TDV8 HSE
Post #379852 Mon Apr 08 2013 1:08pm
mse
throttle preteometer (or however its said) would be a first change item for me...i used to have similar issues on a td5 disco (power and HDC issues) which were down to the throttle position switch failure Mike
Post #379854 Mon Apr 08 2013 1:19pm
potentiometer Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #379869 Mon Apr 08 2013 3:29pm
Page 1 of 3 123>
