![]() | Home > Technical > Power loss |
Thats the one ![]() 2014 Facelift Discovery |
Thanks.
Installed the new brake light switch and ..........IT'S FIXED. Well let's say it completed a 40 mile dash up and down the M1 without doing it - so fingers crossed. The old switch was showing signs of arcing internally at the contacts. I'll post up a 'how to' later as I took some pics. So finally after initially suspecting it was a gearbox fault (that's what it feels like) and spending quite a bit on gearbox service and new battery we have a fault-free RRS. Wonder how long that is going to last? ![]() ![]() |
PaulHH Member Since: 24 May 2013 Location: Highlands Posts: 98 ![]() ![]() ![]() |
Can anyone explain why the Brake Light Switch would cause a loss of power and a Engine Fault Message? I experienced these symptoms today.
Yes. One of the things that the brake pedal switch does is cut the fuel to the engine; this is intended to improve fuel economy and reduce emissions. The switch has two sets of contacts inside it; so apart from controlling the brake lights it also informs the engine ECU that the brakes are on and the ECU takes appropriate actions or inappropriate ones if the switch is faulty. 2008 MY Java Black TDV8 HSE
Cheers for that. Not sure if this is the problem but it's a cheap fix if it is so have ordered one and I'll change the switch as soon as it arrives. It's cheaper to do this than drive the 30 miles to dealer. 2006 Supercharged |
Fitted the switch last week and the error has not reproduced itself, fingers crossed that's it fixed.
Got the error again today. It only happens on the same bit of road each time. Always on a long fairly steep road just south of Inverness. Just cruising around the 70 mph and nearing the top when the loss of power happens with the same Engine System Error happens. Have to stop and turn it off for 30 seconds and then it's fine although it does take the error message about another minute to clear. Still haven't had the error codes read yet. 2006 Supercharged |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
Paul HH - Strange coincidence & a supercharged. I've just cpoied this off a previous thread I replied on?
Cheers Peachy, I actually keep getting low coolant error as well, comes and goes. I'll have to have the Therostat looked at. Is it actually in one of the hoses rather than the water pump? 2006 Supercharged |
Yes - wasn't there when it was fixed - but it was done on my drive in 5 mins by a neighbour - RAC mechanic - I will ask him tomorrow to show me exactly where it was & maybe add a photo - he said its a common fault & went straight for the thermostat - no problems since ( 2 years now ) - guess what |
Peachy, I'd really appreciate that. That'll be excellent if it is the same. 2006 Supercharged |
It was definately this part |
I'll get one ordered up and fit on spec, and then keep my fingers crossed again |
