![]() | Home > Technical > Dynamic response leak |
Markos Member Since: 09 Dec 2007 Location: Ljubljana Posts: 187 ![]() ![]() ![]() |
Chrale I had a DR leak on the ARB which is placed approx. at the rear wheels/axle (a little bit to the front of he car- I would say behind the rear seats) middle to rear seat passenger side is where I had fluid drips on my garage floor. I do not know if this is a common problem but ARB is expensive and it takes about 2-3h to replace it (some LR dealers wil say that they have to take the chassis off but it is not necessary)
Chrale Member Since: 15 Feb 2013 Location: North East Posts: 77 ![]() ![]() ![]() |
This appears to be leaking from the front of the car, there's nothing from bulkhead back over. No drips this morning and level not moved from top up yesterday. I'm starting to wonder if its a pump issue as I'm guessing its leaking when the car is running, which could possibly indicate a seal/pipe weeping under pressure.
So it is not **rear ARB. Hope you will get it sorted out soon 2008 RRS TDV8 HSE, Java black, Alpaca,..... |
Excuse my ignorance but, isn't there ARB's on the front too? 2007 TDV6 HSE |
Yes there is front too (what I meant was that it is not rear ARB sorry for confusion). You should also check Bobby's Gallery where you can see that there could be a leak from the pipe o-rings and not from the hydraulic seal on the ARB. 2008 RRS TDV8 HSE, Java black, Alpaca,..... |
