Home > Maintenance & Modifications > OEM Style LED Signature Halo Lights for 05-09 |
Kimmea Member Since: 10 Jul 2012 Location: Aberdeenshire Posts: 259 |
PM Sent |
Wed Feb 20 2013 9:53pm |
saty Member Since: 17 Aug 2011 Location: Beds Posts: 227 |
PM sent too |
Fri Feb 22 2013 5:20pm |
Andyp247 Member Since: 20 Dec 2012 Location: Somerset Posts: 7 |
PM sent as well |
Tue Feb 26 2013 11:33pm |
Kravman Member Since: 11 Feb 2013 Location: Perth Posts: 11 |
Pm'd you Sparky |
Fri Mar 01 2013 9:49pm |
sparky8181 Member Since: 02 Nov 2012 Location: West Midlands Posts: 588 |
Sat Mar 02 2013 8:31am |
Not got your PM mate, think its because your a new member. You can call me if you like on 07989 597979 |
Sat Mar 02 2013 8:33am |
jorosa Member Since: 01 Dec 2012 Location: Lincolnshire Posts: 25 |
The lights look awesome, but look to be giving out a blue tinge, which I believe looks like 6000k colour temperature (correct m if I'm wrong)
Sat Mar 02 2013 8:56am |
They are white, just look a bit blue in the pics because of the camera as had to mess with the settings |
Sat Mar 02 2013 2:47pm |
Fitted mine at the weekend.
Mon Mar 04 2013 11:34am |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 |
Looking can't wait to get mine installed also Cheers Guy 2006 RRS S/C CONSTANTLY under modification... 1994 RRC 4.2l not LSE sadly gone but not forgotten LR Defender 300Tdi - affectionately know as "The Black Beast" |
Mon Mar 04 2013 12:56pm |
HICKY555 Member Since: 27 Jan 2013 Location: WORCESTER Posts: 208 |
how did you wire them up? RANGE ROVER SPORT 2008
Mon Mar 04 2013 1:38pm |
Cheers Guy
That was the easiest bit of the install. Wired them to the spare positive terminal in the fuse box and then they switch on as DRL. The cable has a unit that detects voltage changes, so when you start the car they come on and when you switch off the engine they turn off.. |
Wed Mar 06 2013 12:50pm |
Excellent diy job here by BAXC, he did such a good job he got talked into doing his brother in laws too
Sat Mar 23 2013 1:08pm |
Welderman Member Since: 14 Jan 2013 Location: Chorley, Lancashire Posts: 146 |
Im currently waiting for the paint to dry and epoxy glue to set so i can carry on doing the lights.
Thu Mar 28 2013 1:24pm |
