![]() | Home > Maintenance & Modifications > OEM Style LED Signature Halo Lights for 05-09 |
Kimmea Member Since: 10 Jul 2012 Location: Aberdeenshire Posts: 259 ![]() ![]() ![]() |
PM Sent |
saty Member Since: 17 Aug 2011 Location: Beds Posts: 227 ![]() ![]() ![]() |
PM sent too |
Andyp247 Member Since: 20 Dec 2012 Location: Somerset Posts: 7 ![]() ![]() |
PM sent as well |
Kravman Member Since: 11 Feb 2013 Location: Perth Posts: 11 ![]() ![]() ![]() |
Pm'd you Sparky |
sparky8181 Member Since: 02 Nov 2012 Location: West Midlands Posts: 588 ![]() ![]() |
Not got your PM mate, think its because your a new member. You can call me if you like on 07989 597979 |
jorosa Member Since: 01 Dec 2012 Location: Lincolnshire Posts: 26 ![]() ![]() |
The lights look awesome, but look to be giving out a blue tinge, which I believe looks like 6000k colour temperature (correct m if I'm wrong)
They are white, just look a bit blue in the pics because of the camera as had to mess with the settings |
Fitted mine at the weekend.
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
Looking ![]() ![]() Cheers Guy 2006 RRS S/C CONSTANTLY under modification... 1994 RRC 4.2l not LSE sadly gone but not forgotten LR Defender 300Tdi - affectionately know as "The Black Beast" |
HICKY555 Member Since: 27 Jan 2013 Location: WORCESTER Posts: 208 ![]() ![]() ![]() |
how did you wire them up? |
Cheers Guy
That was the easiest bit of the install. Wired them to the spare positive terminal in the fuse box and then they switch on as DRL. The cable has a unit that detects voltage changes, so when you start the car they come on and when you switch off the engine they turn off.. |
Excellent diy job here by BAXC, he did such a good job he got talked into doing his brother in laws too |
Welderman Member Since: 14 Jan 2013 Location: Chorley, Lancashire Posts: 146 ![]() ![]() |
Im currently waiting for the paint to dry and epoxy glue to set so i can carry on doing the lights. |
