![]() | Home > Wheels & Tyres > Spare size |
I have a full size 20" alloy with 275/40/R20 tyre and no problems apart from it being more visible as you mentioned. Keep it inflated to the specified pressure. |
It's also a very tiny thing, but it will also reduce your 'exit angle' from decents due to it protruding slightly more, but I guess that's not an issue for 99.9%% of people |
Nottsman Member Since: 29 Jan 2013 Location: Nottingham Posts: 29 ![]() ![]() |
Ok.Fitted the RLD protector and got rid of the skinny spare. Totally impressed with the construction & quality of Uncle Ray's product |
RRSNorway Member Since: 08 Jan 2012 Location: norway Posts: 314 ![]() ![]() ![]() |
Will there be a nagative factor to drive without the spare?
The obvious negative................if I get a flat tyre and there is no spare then the car either has to be towed away or I pay some emergency mobile fitter the best part of £250 to put a new tyre on if the damaged tyre cannot be repaired.
