Home > Wheels & Tyres > Spare size |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 |
I have a full size 20" alloy with 275/40/R20 tyre and no problems apart from it being more visible as you mentioned. Keep it inflated to the specified pressure. |
Tue Mar 26 2013 5:35pm |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
It's also a very tiny thing, but it will also reduce your 'exit angle' from decents due to it protruding slightly more, but I guess that's not an issue for 99.9%% of people ON THE WAY: BMW F21 M140i
Wed Mar 27 2013 2:28pm |
Nottsman Member Since: 29 Jan 2013 Location: Nottingham Posts: 29 |
Ok.Fitted the RLD protector and got rid of the skinny spare. Totally impressed with the construction & quality of Uncle Ray's product ..............the laser cut 'R.L.D' in the centre of the metal plate is a nice touch also.
Tue Apr 02 2013 5:31pm |
RRSNorway Member Since: 08 Jan 2012 Location: norway Posts: 314 |
Will there be a nagative factor to drive without the spare?
Tue Apr 02 2013 8:44pm |
The obvious negative................if I get a flat tyre and there is no spare then the car either has to be towed away or I pay some emergency mobile fitter the best part of £250 to put a new tyre on if the damaged tyre cannot be repaired.
Tue Apr 02 2013 9:26pm |
