Home > General > Brake Discs & Pads |
scott7 Member Since: 20 Apr 2009 Location: Scotland Posts: 282 |
I've used green stuff pads front and back and found them to be excellent, just about to fit a full set again. |
Sun Mar 24 2013 5:53pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Always used green stuff on RS4 on rears and carbon mix AP pads on front. It stops a 1650 kg estate rather well. Found that until they have a little bit of heat in them they squeal a bit. The OE land rover pads are actually quite good but can't work out why they create so much dust and eat discs. By rights it should be one or the other. Unless the dust is the discs 2x TDV6. SE and HSE. Both returned to sender with issues👀
Sun Mar 24 2013 8:06pm |
Kimmea Member Since: 10 Jul 2012 Location: Aberdeenshire Posts: 259 |
Thanks guys, think ill go order a set of EBC green Stuff to see how I get one. |
Sun Mar 24 2013 10:43pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
[quote="simple1"]Found that until they have a little bit of heat in them they squeal a bit. [/quote
Mon Mar 25 2013 6:43am |
If your looking, item number eBay Item No. 280594141479 on fleabay. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Mon Mar 25 2013 8:53am |
Cheers but its a tdv6 with brembos..!
Mon Mar 25 2013 9:25am |
You will need to find out if these were retro fit or not. If they are then possibly off a supercharged in which case I think it's the same pad/disc as TDV8 2x TDV6. SE and HSE. Both returned to sender with issues👀
Mon Mar 25 2013 9:34am |
These were factory fit at a guess as the previous owner wouldn't have swapped them out at a guess |
Mon Mar 25 2013 9:37am |
Don't know what year your car is but when I ordered my second V6 @ 2006, these were not an option and were fitted to SC only. In 2007 they were standard fit on V8 so think a call to supplying dealer may help. Have seen a few v6 and discos with Brembos but when you talk to owners, they have fitted them themselves. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Mon Mar 25 2013 9:45am |
Hmmmm ok I'm out of the UK but home tomorrow so ill check that out then.
Mon Mar 25 2013 9:53am |
Sent you a PM 2x TDV6. SE and HSE. Both returned to sender with issues👀
Mon Mar 25 2013 10:03am |
