![]() | Home > General > Brrrrr.... Aux Heater |
That's an interesting question as I have never really paid attention in 8 years of owning these cars. Am sure it warms up reasonably quickly compared to the three hours my L200 takes to blow warm/hot air. If the FBH is firing up, it will be warming the water system but as far as I can gather, it warms the entire cooling system including the block so its never going to generate instant heat. Sounds like you may need the remote heater start system as sold by I think, a site sponsor. 2x TDV6. SE and HSE. Both returned to sender with issues👀
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9030 ![]() ![]() ![]() |
If it's getting up to full temperature (on the gauge) in 10 minutes then it's working fine. Mine does it in about that time from a 0 degC start. When it wasn't working recently, the gauge didn't get fully up to temp in much less than 20 minutes. So there is a noticeable difference. 2012 SDV6 - it's missing a couple of cylinders
Simon0566 Member Since: 01 Mar 2013 Location: Warickshire Posts: 9 ![]() ![]() ![]() |
Thanks for the responses.
